93 Splash in SC, V8-Swap version
Featured Build Threads
that fuggin thing is gonna be a problem.
have you rode your bike with it yet?
better check that
better check that
No. Haven't ridden the bike yet. Don't want to get shocked while riding. I'm waiting to see what the permanent implant is like.
For fawks sake.
hey.....riding the kawi is priority....i have not even got to go on a ride with him yet.
i think he is fine. ready to go back to work. just have to be leary of magnetism...which means the plant is a mine field.... so thats a fuggin problem.
so ... yeah. get the ranger going and go riding.
This is more than a tinfoil hat kind of situation...
Haven't had trouble with the microwave, yet. But that is something to be aware of, especially the higher wattage commercial ones.
Drink more beer.
We used to sell an electronic monocular magnifying device that had magnets in it that would mess with pacemakers. It was serious enough that we had to have people sign a waiver before they were allowed to buy it. Kind of a stupid concept since it's target market was old folks with vision loss - the most likely to have health conditions as well. I imagine there are a lot of things out there that can mess with that stuff.
Eric needs a Duraspark conversion.
It's coming soon. I see the surgeon next week to schedule it. I was going to ask for some kind of MSD HEI version. With the right system, I could interfere with the lawn mower instead of it interfering with me.
Progress? I finally packed my bag and came back home this evening. I will still have to go to moms house daily and coach her PT exercises, do her grocery shopping weekly, druve her to appointments and help with a few other things. But I can start getting back to my life now.
She can use a cane if she wants to. That frees up a hand to carry things like travel mugs or a plate of food. It also makes it easier for her to maneuver in the kitchen. I got her set up with easy meals to make. The biggest issues are her dementia and getting her to take walks and exercise daily in addition to the therapy exercises. She wants to be independent and be able to walk and drive. But it's a struggle to get her to exercise. If she doesn't exercise, she won't continue to heal and build strength and that independence won't happen.
Spent some time yesterday and today working in the underhood wiring harness. Much easier since I spent all that time planning and making drawings.
I have re-purposed an auxilliary relay box from the Explorer that has 6 relays. Two for headlights, high and low beams, to accomplish the headlight mod that we like around here. And the other 4 are for a trailer wiring harness. Left and right turn signals, reverse lights and parking lights. Those 4, plus a steady 12volt battery supply and a good ground will travel through a 7 conductor cable to a 7 pin round trailer connector at the rear bumper. I could add a brake controller in the future.
Now, you ask "Eric. When is the last time you towed a trailer with that truck? And what trailer requiribg a 7 pin connector do you think you will ever tow?". I don't know. Just let me have my fun. I put the multifunction switch from the Explorer on my new steering column. So it has the right connections inside and I had the wiring diagrams to figure it all out. So, while the truck is apart and it's easy to do the wiring, I'm doing it. Plus, this (mainly the better multifunction switch) now converts my original truck wiring so that I don't need the funky wiring adapters at the rear to control the trailer light assemblies that I used as tail lights on my custom bed. I get to clean up a lot of messy wiring back there. Back into a rock or tree and destrot a tail light assembly? Just stop at Harbor Freight, Northern tool, or auto parts store and buy a cheap new assembly.
The auxilliary relay box
This harness will get a Delphi weatherpak 7 pin connector and a 7 conductor cable will be routed to the rear of the truck.
@Curious Hound , so as to the 7-pin trailer plug, I wired our little trailer to a 7-pin and I’ve been converting my fleet to all have 7-pin plugs even if I don’t put a brake controller in the truck. The biggest reason? It simplifies things and gives me the ability to have backup lights on the trailer. I’d also like to put electric brakes on the little trailer because people are stupid and trailer brakes make a difference.
I also put a pintle ring on the little trailer. I don’t trust ball hitches that much.
Slowly working on the wiring harness. As I was looking at wires for the clutch jumper/NSS mess, I found that one of those wires tied to the fuel tank pressure sensor in the Explorer. It's just emissions garbage. But I don't want to just omit it and have the CEL on. And I don't have the money to delete it with sofyware right now. So, I needed 3 wires and the right connector to go back to my fuel tank so I can install a pressure sensor.
Hence, todays project. I removed the wiring harnesses associated with that. Those wires traveled 1/2-way in the interior and then through the floor and along the frame rail. So, I removed the entire interior wiring harness on the driver side. I cut the wires going to the passenger side and up to the roof. Gained another relay box and found some electronic module hidden behind the plastic trim.
Event Coverage
Featured Ranger Based Vehicle
