93 4x4 wheel bearing question
Featured Build Threads
87RangerXLTct
Connecticut
2.9L
Stock
Stock
235/75/r15
I'm in the middle of a brake job on my 93 4x4 stx with the Dana 35. I cleaned and repacked the wheel bearings. When I assembled the passenger side I put bearing part number LM603049 as the inner bearing (closest to grease seal). But then when I took apart the drivers side I see that bearing is on the outside (right behind the wheel bearing adjusting nut)?! My question is did I install the bearings in the wrong place or was it backwards to begin with?
The spindles and bearings look to be in good shape on the passenger side, the drivers side spindle looks a lil suspect and that’s the one with the 603049 on the outside
Pictures of the drivers side
  • 93 4x4 wheel bearing question
Just popped the wheel seal off the drivers side and I see the inner and outer bearings are the same part number? But in the passenger side there was lm603050 as the outer bearing?
On 4x4, both inner and outer bearings are the same. It could be that one of those part numbers is a complete bearing and one is just the inner race with rolling elements. Sometimes people re-use the outer race or use the one that comes with the new rotor.
It is best to replace the complete bearing so that you know all parts of it were machined to the same tolerance by the same manufacturer.
Thanks for shedding some light on that. I’m putting new rotors on that came with new races installed. As far as I can tell these are all OE bearings, truck only has 60kmiles.
Did you file or sand that spindle? If not, then someone has worked on it before. It has definitely been worked on. Plus, I'm not sure Bower is a brand of bearing that Dana would have supplied with that axle.
Rare find if you got a 93 Ranger with only 63,000 miles. It's often difficult to know since the odometer doesn't display higher than 99,999.9
No the spindle was like that already. I agree it definitely looks like someone messed with it.
The truck has been parked for 20 years or more, the shop that sold me the truck bought it at auction where it was listed at 60k miles. I know it’s hard to tell without carfax and stuff. But the pedals have nearly any wear, granted those could’ve been replaced. All the hoses and belts seem to be factory. But this spindle has me rethinking all that lol
The truck was never undercoated, and the floor pans underneath and frame are all clean. Which for being in Connecticut it’s whole life it definitely hasn’t seen many winters on the road
Parked for 20 years makes the low mileage more plausible, as does "little wear on the pedals". Nice find. You will likely find things that need fixing. But they will show up slowly as you drive and use it. Machines don't often age well when they just sit idle, especially outside in the weather. It's better to be operated regularly. But that should be a great truck once you get to know it.
Mine sat for about 10 years before I bought it. So I have no problem believing there is another "1" at the left end of my odometer reading. The overall condition of the truck bore witness to the miles, also.
Event Coverage
Featured Ranger Based Vehicle
