- Feb 15, 2020
- Southern maine
- State - Country
- ME - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Total Drop
- Shackle flip
- Tire Size
- 235/60/15
- My credo
- Its probably better to be self deprecating than self defecating.
I got it from Menards, which is kind of the Harbor Freight of construction I suppose. The tongue is a piece of 2X3Xthin rectangular tube, and is bolted between two pieces of angle iron welded across the first two cross braces. So when loaded, it's pulling down on the second cross brace, and pulled the vertical leg of the angle iron apart. I never did like the way that was set up and vowed to change it, but other things always took higher priority. I found the crack when re-wiring the lights and figured I'd better fix it sooner than later. I did notice it welded weird. It was kind of inconsistent and would burn through in places, using my usual settings for 1/8" steel. I wonder if they make them from bed frames?
Yeah your trailer and this trailer are definitely the same lol.
