'85 Ranger Restomod
Car show...two weeks. You going to make it?
I will be there... truck ain’t looking good though.
I didn’t have enough faith to preregister at the meeting last Wednesday...
I always thought a speedi sleeve needed thread locker or the equivalent to prevent seeping under the sleeve. Once the locker is cured it shouldn't move.
I asked dad about it this morning, he said there is no way I should have been able to more or less push it in place by hand. And he has never had one shift while putting the seal on.
He says there is no way it could be the correct size for the crank.
I have never installed one before so it is all news to me. It was snug but I didn't NEED the tool or a hammer.
I will let you know, we will be up in your neighborhood at the end of the month.
I probably have a good set of floor pans too.
Bring a sawzall.
:thefinger:
Or a trailer, you can take a cab home with you :D
Bring a sawzall.
:thefinger:
A floor pan is cheap, cab corners are where it gets problematic to find. If you have a good pair of them...
I am going up with my brother in a Mustang for the Mustang Rally in Sturgis... probably a no on the trailer.
EDIT:
Not much accomplished tonight, I did get the crank cleaned, the NSS wiring isolated, a plan formed to delete it and re riveted the heat shield under the bed.
'85 Ranger Restomod
Well one part I wasn't to the point of waiting on is ready for paint...
'85 Ranger Restomod
I have the new speedi-sleeve too, fingers crossed I can get the trans in tonight...
If you dont mind me asking, how much that spacer run you?
'85 Ranger Restomod
Sent from my LG-LS997 using Tapatalk
They quoted me $15, the guy that does the invoicing wasn't there and the guy that was there didn't know where and/or if it had been done.
I couldn't make it myself for $15 and if I did it wouldn't look nearly as nice.
I did draw it up on draftsight first though so they didn't have any labor into designing it, just drag and drop onto their computer and get it nested into their next run of 3/8.
That's a good deal! Definitely worth getting a perfectly cut piece.
That is kind of what I thought, even at $50 it is an awesome looking piece.
Anyway, actually covered some ground tonight:
Found this in my clutch kit, yet another slave cyl o-ring, don't know what the bigger steel ring is for.
'85 Ranger Restomod
LSC003 is the slave minus the throw out bearing:
'85 Ranger Restomod
Used a block of wood to drive on the sealing ring, stuck the flexplate back on it and gave it a few love taps with a deadblow to get it on the last 1/8". FYI that thing is really friggen sharp, I cut my finger about as bad as I ever have on that internal lip.
'85 Ranger Restomod
'85 Ranger Restomod
Pilot bearing and rear seal:
'85 Ranger Restomod
And separator plate:
'85 Ranger Restomod
And flywheel:
'85 Ranger Restomod
So tomorrow night is the PPA/disk and hopefully trans...
Fought off heat, disease and injury but trans is in. :yahoo:
'85 Ranger Restomod
[url=https://flic.kr/p/MPdnYS]'85 Ranger Restomod
'85 Ranger Restomod
'85 Ranger Restomod
It is high enough to get the trans jack under it, now it is time to move in for the kill...
'85 Ranger Restomod
but wait, the firewall seam is in the way
'85 Ranger Restomod
Get some vice grips and give it an attitude adjustment
'85 Ranger Restomod
10:30, it was hot, my nose was running from a cold that came on about halfway thru the process and I had about headbutted everything sharp I could find under the truck I could so I stuck the crossmember and a 2x4 scrap under it and called it a night. Crossmember is going to be very close to lining up with the holes in the frame from when the A4LD was in the truck.
'85 Ranger Restomod
Stock '88 floorplate:
'85 Ranger Restomod
Gotta test fit the new shifter, kinda neat in neutral it has the same angle as the steering column (just noticed that):
'85 Ranger Restomod
Great progress bud. Hope you feel better soon!
I had high hopes of getting the rest of the bellhousing bolts in it and getting the driveline angle set tonight.
Right now I just want to sleep. :bawling:
Trans is sitting on its mount mount bolted into the old A4LD holes all nice and pretty.
'85 Ranger Restomod
Much slimmer than an automatic.
'85 Ranger Restomod
'85 Ranger Restomod
Ok, that is secure, lets get the last two bellhousing bolts in but wait...
'85 Ranger Restomod
Remove crossmember and let the trans down...
'85 Ranger Restomod
Then poke the crossmember back in.
Ok feeling brave now, time for the t-case.
'85 Ranger Restomod
I got it in there lined up and everything was looking great but it wouldn't go the last little bit. Discovered the countershaft pin was hitting the transmission case. So I had to back the t-case off and hacksaw the corner off the transmission. Kinda almost seems like this transmission and t-case were never intended to go together by now doesn't it?
The nut between the input and front output is on the countershaft pin.
'85 Ranger Restomod
The bottom left (drivers side) corner of the transmission is what is hitting.
'85 Ranger Restomod
The factory mounting was just round and offered no such interference.
'85 Ranger Restomod
So with a liberal application of a hacksaw (that I really need to remember to get a new blade for) that corner is gone. Not sure if that counts as cutting corners or not...
'85 Ranger Restomod
'85 Ranger Restomod
And IT IS IN!!
'85 Ranger Restomod
I need to work on where it mounts to the frame rail, mainly get a piece of angle iron I think and get the bushings for it. It is hanging from a single 3/8" bolt at the moment with the jack under it helping a little bit.
'85 Ranger Restomod
Its late, I probably should be heading in but dang that 4wd lever boss looks really nicely placed...
'85 Ranger Restomod
Heck ya! Now I need to figure out how to get two levers to do that... (can also see better how the transmission fits around that countershaft pin/nut)
'85 Ranger Restomod
I had a third gen Explorer driveshaft in my parts cache... and it is too short. I don't think my driveline is any shorter than it was with the little C5/1350. The compact 205 is making up for the longer M5R2.
'85 Ranger Restomod
Glued in the t-case bolts last night. Biggest gripe about this case aside from its weight is every freaking hole is a thru hole and pretty much every bolt has to have sealer on it. Can't wait to see how many leak...
Nice easy access from above:
'85 Ranger Restomod
I had 5 bolts in and tight, #6 would not start at all, top PS one.
'85 Ranger Restomod
Guessing maybe 1/8" off... not sure how that worked. I probed it and it was not my ring,the t-case itself was off. So I loosened the other 5, got a jack under the t-case and twisted it up some and got that bolt started. Let the tension off and all bolts turned freely by hand so I don't think anything is in a bind now. Weird deal...
Anyway, played with t-case levers some more.
Both will clear the stock floor hole:
'85 Ranger Restomod
Trans is in second, it can't get any farther to the left. Lever probably wouldn't be bad if not twin sticked but another one outboard of that one could get obtrusive. Thinking of straightening and shortening them. At least shortening them anyway.
'85 Ranger Restomod
Did some research on what t-case bracket is supposed to look like, shouldn't be too hard to replicate.
'85 Ranger Restomod
https://shop.broncograveyard.com/NP-205-Side-Brackets/productinfo/21673/
I don't need that much reach (as if my frame is narrower than a fullsize or something) so a stock/stock replacement one won't do me much good. Bushing is interesting though. It actually goes thru the plate I need to make.
'85 Ranger Restomod
https://shop.broncograveyard.com/19...sfer-Case-Side-Mount-Black/productinfo/23095/
Dad was over and I was showing him my progress, he commented now would be a great time to fix the floor pan. I know, still working out how I want to do it. At my house I have no air tools, could borrow my FIL's little welder though. Wonder how well my oscillating saw will cut a steel floor...
I did some more playing with the levers last night, they are a little baggy on the bolt but I think they will work nicely.
'85 Ranger Restomod
All the way ahead:
'85 Ranger Restomod
All the way back:
'85 Ranger Restomod
Featured Ranger Based Vehicle
