INFO 2019+ Ford Ranger Problems - Share Yours
Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
TRS Banner 2012-2015
GMRS Radio License
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
Let's start compiling known problems with the 2019+ Ford Rangers. What have you experienced?
Ford Touch Screen
Me personally, I had a 2019 Ford Ranger where the display screen for the radio / navigation / climate controls froze. The radio continued to play, but the display screen was completely frozen. I couldn't even turn the radio off by pushing the power button. If this happens to you, hold down the power button and the fast forward button at the same time for 15-seconds.
Windshield
I'm on my 2nd broken windshield in the 2021 Ford Ranger FX4. Unlike the previous Rangers, Ford didn't put a rubber trim piece around the outside edge of the glass and there's a gap between the glass and the windshield post. If a rock hit the corner edge of the glass it will crack it. My current windshield has three spots along the passenger edge of the windshield that were struck by rocks and caused three different cracks to go across my windshield. This wouldn't be a problem if Ford still put a rubber trim in that gap. You can find rubber trim for windshields online. Whenever I replace this windshield, I plan to invest in rubber trim to go around it.
Rear Pinion Seal Leak
I discovered that my rear pinion seal on my 2021 Ford Ranger FX4 was leaking back in December, but the pinion itself seems to still be tight. I ordered a seal but have not yet figured out the cause. It could be from a plugged axle vent tube causing it to build up pressure. I need to investigate it more now that it's warming up. It only leaks when I drive and I didn't lose that much driving to Ohio for Christmas. I just keep an eye on the fluid level and top it off if needed. I'll update this post when I fix the problem.
Wheel Speed Sensor
I drove off of a curb pulling out of a parking lot and the 2021 Ranger FX4 started flashing these error messages:
  • Service AdvanceTrac
  • Pre-Collision Assist Not Available
  • Terrain Management System Fault
As well as the ABS and Traction control lights.
I used a scan tool and didn't get any codes, so I hooked up forscan and got the following DTCs:
PCM: U0422:00-2F (diagnostic trouble code that occurs when the other control modules on the vehicle are not communicating with each other)
PAM: UO415:00-2B (invalid data received from the ABS control module)
FCIM: B113C:11-48 (can't find a definition)
ATCM: U3000:49-08 (The module has permanently disabled an output because an excessive current draw fault (such as a short to ground) has exceeded the limits that the BCM can withstand)
ABS: C0037:65-C8 (Left Rear Wheel Speed Sensor: Signal Has Too Few Transitions / Events)
PSCM: U0415:00-08 (Invalid Data Received from Anti-Lock Brake System (ABS) Control Module)
IPMA: U0418:86-AF (Invalid Data Received From Brake System Control Module)
I unplugged the left rear wheel sensor, plugged it back in, and then used forscan to reset the DTC's.
The error hasn't come back since and that was July 2023.
Transmission Slips
Back in January 2023, I pulled out of a parking lot in the2021 Ranger FX4 in the freezing cold and the transmission in my 2021 Ford Ranger slipped for a brief moment and then engaged.
No Power On Cold Acceleration
I've had a couple of experiences where I've pulled out of my driveway in my 2021 Ranger when it was cold (50 degrees or below) and the truck didn't respond for a moment when I gave it gas. I try to let it warm up for a while before I drive it.
Please Share Your Experiences
Maybe we'll find a common issue or post a problem and solution that will help someone else later.
no issues on my 24 ranger.
my son has had to do the hard reset a few times on his 24 ranger radio/hvac screen because his apple phone and the truck don't seem to work together properly. he said its enough of a problem he wants to get something else instead of the ranger.
Hello from the UK, I notice your start button is on the wrong side in the picture ;)
Thank you for mentioning the wheel sensor issue - I have just had the same spam warnings - you have given me somewhere to look.
Ford Commercial want £170 to investigate per issue! (apx $230)
I assume both his phone and the truck are current on updates?
Sometimes one of them will update and get ahead of the other and cause issues. Both can update automatically on their own.
I have no idea. He said that is his one issue with the truck. I told him to just listen to fm, thats what i do but he said he uses the maps alot because his unit sends him tdy every week
When I was at Chrysler that was a common issue, one wouldn't be updating and the other would be staying current on automatic updates until eventually it would advance beyond the other's ability to communicate.
I will let him know
Not quite an issue I can't deal with. But my air conditioning bleeder door has been clicking for years now when on auto. If you set the temp like old school and just adjust the fan speed it doesn't do it. I guess it the truck trying to maintain the temp by opening and closing the door. I've been told you have to remove the dash to replace it. That being said I saw on FB or somewhere that there is a video on YouTube that shows you how to do it without removing the dash. Seems to be a common problem among all dual zone systems. When I asked the guys at the body shop.about it. They informed me they have fixed one F150 and three different Chevrolet trucks.
Second is the carrier bearing on the 2 peice drive shaft. I had to replace mine at 40k. I did just recently find and upgraded aftermarket version. It has a lager sealed bearing with less rubber around it. It also has a 2 peice carrier. That clamps around the bearing.
These have been the only real issues I've had that seem to be common. I have bent a rear leaf spring and just replaced the rack and pinion. That being said I dont see those as common problems over all but more on the conditions I put my truck through.
I've seen posts off and on about the blend door issue but not much on what was done to fix it. Typical facebook.
I bookmarked the carrier bearing you speak of. Hopefully, I can get to a point where I can do some preventative upgrades to the truck. That will be one of them. The other will be getting a valve body from Next Gen Drivetrain that is supposed to fix most of the issues with these transmissions. I had thought about the single piece driveshaft swap, but those increase the likelihood of the driveshaft hitting something. at $600+, I'd rather spend the money on the better carrier bearing for now and maybe worry about a single piece if there ever come a time the driveshaft needs replaced.
As far as the issues with the Ford electric assist steering racks, they are a known issue but are apparently not a bad enough one to be more than that. I'm sure us fording through bodies of water hasn't helped. Though neither Snoranger or Jim seem to be having any problems. So, I guess it's a hit or miss thing. But across the different Ford models that have them, they all seem to have posted about water issues with the racks.
Yes when researching the fault I saw they issued a recall on. The Transit and Escape on the EPS rack. From 17-20 if I remember correctly.
I had an intermittent issue for a year or so where no sound would come out of the rear speakers. Dealership did not do anything because they could not replicate it at the time. Did not seem to vary with temperature, I couldn't determine any pattern to it. It basically acted like it does when the proximity sensor is beeping and it kind of mutes the stereo. Fixed itself about 6 months ago, I wonder if Ford slipped in a software update that resolved it but I have no idea.
Shifting at lower speeds is slippy/clunky. Dealership said it was a known issue and replaced some part, I forget what it was but it was still the same so then they replaced the entire transmission, still pretty much the same so I just accepted it.
My 21 ate it's driveshaft center bearing at 40k, danas fault.. not Ford's. Bad batch of bearings.
3rd brake light started to leak water into the cab, classic Ford issue.
Headlights would flicker.. fast enough where youd question whether or not they actually flickered or you just blinked... But It was definitely a flicker..
Transmission started its death process right before I traded it in.. at 42k.
