INFO 2019+ Ford Ranger Problems - Share Yours
Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
Let's start compiling known problems with the 2019+ Ford Rangers. What have you experienced?
Ford Touch Screen
Me personally, I had a 2019 Ford Ranger where the display screen for the radio / navigation / climate controls froze. The radio continued to play, but the display screen was completely frozen. I couldn't even turn the radio off by pushing the power button. If this happens to you, hold down the power button and the fast forward button at the same time for 15-seconds.
Windshield
I'm on my 2nd broken windshield in the 2021 Ford Ranger FX4. Unlike the previous Rangers, Ford didn't put a rubber trim piece around the outside edge of the glass and there's a gap between the glass and the windshield post. If a rock hit the corner edge of the glass it will crack it. My current windshield has three spots along the passenger edge of the windshield that were struck by rocks and caused three different cracks to go across my windshield. This wouldn't be a problem if Ford still put a rubber trim in that gap. You can find rubber trim for windshields online. Whenever I replace this windshield, I plan to invest in rubber trim to go around it.
Rear Pinion Seal Leak
I discovered that my rear pinion seal on my 2021 Ford Ranger FX4 was leaking back in December, but the pinion itself seems to still be tight. I ordered a seal but have not yet figured out the cause. It could be from a plugged axle vent tube causing it to build up pressure. I need to investigate it more now that it's warming up. It only leaks when I drive and I didn't lose that much driving to Ohio for Christmas. I just keep an eye on the fluid level and top it off if needed. I'll update this post when I fix the problem.
Wheel Speed Sensor
I drove off of a curb pulling out of a parking lot and the 2021 Ranger FX4 started flashing these error messages:
  • Service AdvanceTrac
  • Pre-Collision Assist Not Available
  • Terrain Management System Fault
As well as the ABS and Traction control lights.
I used a scan tool and didn't get any codes, so I hooked up forscan and got the following DTCs:
PCM: U0422:00-2F (diagnostic trouble code that occurs when the other control modules on the vehicle are not communicating with each other)
PAM: UO415:00-2B (invalid data received from the ABS control module)
FCIM: B113C:11-48 (can't find a definition)
ATCM: U3000:49-08 (The module has permanently disabled an output because an excessive current draw fault (such as a short to ground) has exceeded the limits that the BCM can withstand)
ABS: C0037:65-C8 (Left Rear Wheel Speed Sensor: Signal Has Too Few Transitions / Events)
PSCM: U0415:00-08 (Invalid Data Received from Anti-Lock Brake System (ABS) Control Module)
IPMA: U0418:86-AF (Invalid Data Received From Brake System Control Module)
I unplugged the left rear wheel sensor, plugged it back in, and then used forscan to reset the DTC's.
The error hasn't come back since and that was July 2023.
Transmission Slips
Back in January 2023, I pulled out of a parking lot in the2021 Ranger FX4 in the freezing cold and the transmission in my 2021 Ford Ranger slipped for a brief moment and then engaged.
No Power On Cold Acceleration
I've had a couple of experiences where I've pulled out of my driveway in my 2021 Ranger when it was cold (50 degrees or below) and the truck didn't respond for a moment when I gave it gas. I try to let it warm up for a while before I drive it.
Please Share Your Experiences
Maybe we'll find a common issue or post a problem and solution that will help someone else later.
no issues on my 24 ranger.
my son has had to do the hard reset a few times on his 24 ranger radio/hvac screen because his apple phone and the truck don't seem to work together properly. he said its enough of a problem he wants to get something else instead of the ranger.
Hello from the UK, I notice your start button is on the wrong side in the picture ;)
Thank you for mentioning the wheel sensor issue - I have just had the same spam warnings - you have given me somewhere to look.
Ford Commercial want £170 to investigate per issue! (apx $230)
I assume both his phone and the truck are current on updates?
Sometimes one of them will update and get ahead of the other and cause issues. Both can update automatically on their own.
I have no idea. He said that is his one issue with the truck. I told him to just listen to fm, thats what i do but he said he uses the maps alot because his unit sends him tdy every week
When I was at Chrysler that was a common issue, one wouldn't be updating and the other would be staying current on automatic updates until eventually it would advance beyond the other's ability to communicate.
I will let him know
