2011 Ranger XLT 4X4 - "Business Casual"
Featured Build Threads
But, that's the byproduct of articulation.
Or, maybe farticulation in your butts case.
Correct! And a set of fox coilovers articulates much better than v8 explorer torsion bars with rough country leveling keys.
Also, the farticulation is a winter project if I can ever find a set of FX4 buckets...
Electro tank back in full swing... this is just electrolysis, no sandblasting. Thing was solid scale and por 15 (ha...) when I started.
Not too shabby.
The powder coating I did, however...
Shitty, but I'll take it. It's a spindle after all.
Electrolysis tank at it again.
I really should do a write up on how to make one... most useful tool I've ever built, made from random junk and an ebay stick welder. Strips rust and old paint and powder coating indiscriminately
please do.
question, which works better, electric or gas oven?
fume go boom??? :icon_rofl:
I've heard it can be done with a car battery charger.
please do.
Just because I'm producing pure hydrogen gas right next to an oven doesn't mean anything. Idk who this Osha lady is, but she sounds like a b...
Nvm. 😁
Electric works much better for degassing/powder coat
You can, but it is extremely wimpy.
I started with a battery charger, then moved on to a benchtop power supply, and then finally a welder. The thing runs so much juice to the tank that it will heat up and boil off a lot of the water.
The other big modification that I made was that I use carbon plates instead of steel as my sacrificial anode. Carbon tends to last a lot longer, you don't wind up with orange gunk everywhere, and it leaves black carbon residue which is totally inert on the parts so you don't have to worry about getting it completely clean before you paint or powder coat. The drawback is carbon requires a lot more juice due to it only being a semiconductor, but eBay welders are like $75 and Supply more than enough amperage on the lowest setting
What amperage for what size tank?
A decade ago I made one and used a dumb battery charger. Worked good for the size, iirc was 10 amp. Now I use vinegar for small stuff.
Tank is a 55 gal plastic drum with a 12in-ish slit cut down the side, on a homemade stand. Holds roughly 50 gallons of water. And I leave it around 25 amps IIRC, but can put the boots to it if need be.
I'm almost done building my own powder coating oven out of an old hearing test audio booth and a free electric oven. Test results are promising so far on temperature holding, but it needs a little more sheet metal for lining still. It will be large enough to do bumpers, wheels, etc.
I may have to cobble up an electrolysis tank...
Featured Ranger Based Vehicle
