2002 Ranger electric transfer case conversion
Featured Build Threads
mexsudo
Forum Member
Ensenada, Baja California, Mexico
N/A
Other
In the autumn of my years
Vehicle
Drive
235/75R16
I have the electric transfer case, automatic transmission.
it's not working correctly, and while I am preparing a work area for the repair I'm thinking I would love to reduce the complexity.
So, I am considering conversion to manual shift transfer case.
I suppose IF I could find a Manual transfer case in one the wrecking yards with the lever it would not be a huge job.
But, there always seems to be a glitch in such things.
Maybe there is a better way, that I can afford.
searching the forums I'm not finding anything exactly on point.
I got a spare for my conversion for like $95 shipped off car-part, but no shifter and no floor plate. Hypothetically you can fab both, but not having the floor plate sealed properly has always been super noisy for a daily, and I hate it.
The only way you're gonna get that shit at this point, outside of a u-pull-it or an angel descending from heaven, is to buy an entire donor truck with a bunch of parts you want for cheap because there's something major wrong with it and haul it home. I've also paid the seller of such a truck extra to haul it across the county for me. I'm not sure how high of a redneck factor you're interested in, though.
I'm in Mexico so availability is different... that question is unanswered at the moment.
But, it seems you have done this... was it just as simple as dropping the shafts, R&R, and then replace the shafts? (hole in the floor for the stick and boot is assumed)
as in "It just works"?
Being that you are in Mexico, the information we have might not be helpful to you.
One thing to look for is the threaded holes on the transmission in order to be able to do the conversion. If they aren't there, you are probably looking at a transmission swap. If you can, compare a truck with a manaul case to yours before you spend any money.
The reason I point this out is that later models of the North American Rangers no longer have the needed holes to mount the bracket and linkage for the manual shift.
It was originally sold in the USA, then imported. So it's an American version.
Thanks for the heads up.
It is not the transmission that needs to be changed, it is the extension housing that has the mounting holes for the shifter linkage. If you find a transmission with the correct extension housing that is good. That is probably easier to do than finding the correct extension housing by itself.
There is a way to modify the electronic shift extension housing to be able to mount the linkage. There is an article in the TRS Tech Library that gives a not so detailed way to do it. Then you have to find the shifter linkage and manual transfer case. The best bet for a newer setup is the 2002 FX4 or the 2003 FX4 Levell II with the manual transmission. There were not a lot of them made but as they get older it may be easier to find one in a salvage yard. Probably not a good source on Mexico.
is this the article?
Behemoth Drivetrain sill has the Borg Warner Electric to Manual Shift Conversion Kit in stock for $995.
the videos and photos are very helpful.
probably beyond my budget, thanks
Excellent. This method is affordable, once I find the donor...
... I'm hopeful on that.
We have a wrecking yard Whatsapp network here in Baja. ...I will have my wife put the word out.
If I need to source in the USA I can have it shipped to my mailbox service in San Diego, all damn day to go and return but doable.
¡Ay, caramba! ... from $300 to $1,000!!?? FFS, could someone please pull the knife out of the back of ALL Ranger enthusiasts? :mad::fie:
OK, maybe a bit harsh... TBF their BILLET units are friggin' WORKS OF ART, but... it's OVERkill, a solution looking for a problem. Cheap castings work FINE in that application! I mean, are you going to take your GF on a date, UNDERNEATH YOUR TRUCK?? Is Car & Driver Jim Oaks/TRS sending a crew over to do a photo-spread on YOUR drivetrain? :no2:;)
PS: while I WISH my '99 XL had come with the FX4 manual t-case (and cool bent-back main shifter), I just got a NEW, no-core-charge Dorman shift motor for ~$51 incl. shipping, and the original OEM one failed (rusted, seized) from UNDERuse, not wear-and-tear, so even though I no longer live close to "off-road" country, I'll make sure to find an vacant lot or construction site to "exercise" the 4WD once or twice a month... that way, I'm ready for Hurricane Season! #JustNOTworthTheConversion$$
castings are not cheap in the numbers that will sell.
per build or limited run of 50 on a cnc makes sense in many points.
rangers are for people on a budget by far, this is why bolt ons are so limited.
just make your own linkage. it is easy to shift a manual shift t case. and the e shift systems on the early rangers are easy to work with as well...you can rob a 150 setup too.
even if you swap a modern powertrain shifting the t case is not horrific,,,,
stand alone systems combined let you do what you want....building it yourself can be cheaper if you already own the tuning architecture have hp tuners ect...
True that--upfront tooling/mold costs!... but if they started with the castings off of old electric shift motors, then we're talking only what, a piece of 3/16" stock steel plate and drill some holes? Just trying to foil FoMoCo's evil plan to make our Rangers "obsolete", and force us to buy unibody "Broncos"... :p ;)
Has nobody ever written up building cable-shifting for these cases? Either a push-pull cable with a manual tcase, or a rotary cable with a Shiftster?
Event Coverage
Featured Ranger Based Vehicle
