4.0 into 88. Check my facts.
Nate.Mountain
3
Idaho Falls, ID
2.9
Greetings everyone.
I am about to pull the trigger on a 4.0 swap into my 88 2wd 5spd. I have researched this swap for some time and would like to know if there are any hiccups in what i have planned.
Engine: 4.0 out of a 1992 Aerostar (from my understanding, the same motor as the explorer and ranger minus the exhaust manifolds which will have to swapped)
Engine Harness: Complete Harness and ECM out of a 1992 Ranger Manual. I have read a harness out of a 90-92 ranger are the best.
Trans: I have a 5 speed m5od which I will keep. I will use the 4.0 clutch, flywheel, throwout bearing, and pressure plate.
Starter: 4.0 Manual starter. Also read that if you leave the spacer that is behind the flywheel you will need an auto starter. Is that true?
Fuel lines: Must either be replaced entirely or spliced. Leaning towards splicing.
Dash: "Easier" to swap but I would much prefer the original ranger dash. I have a EVTM for my truck and will order one for a 1992 ranger. Splicing will be a slow process but I think/hope i can figure it out.
Exhaust: I think I can reuse the same exhaust, not positive though
Radiator: Larger radiator from an auto 4.0 with AC is recommended
Does anyone see anything I am overlooking? Ill take pictures as I go and try to help others interested in the same swap.
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Do you currently have a 2.9? Your Y pipe will work with the 4.0 manifolds.
All of your facts look good to me. I don't remember what the '88 has for fuel lines, but splicing them with nylon fuel line and plastic fittings is cheap and simple; it's what I used to move my gas tank to the rear.
Everything is more or less "bolt in". Splicing the engine harness will probably be the most fun, but as long you have the manuals for both it should be easy. I have the 1992 factory manuals if you need some pics of the diagrams.
Edit:
I posted a bunch in this thread already
LINK
Nate.Mountain
3
Idaho Falls, ID
2.9
Thanks for the reply. Slight change of plans in regard to the engine. I'd found one today out of a 91 ranger that's two hrs away but less miles than the aerostar engine. Will be picking it up Monday morning.
Nate.Mountain
3
Idaho Falls, ID
2.9
Update
Small update for today. Picked up the 4.0 from the pull a part. Out of a 92 Aerostar. Had 110k on the clock. Has suffered from leaking valve cover gaskets for who knows how long. Spent a coupe hours cleaning up all the grime. Have a lot of cleaning left to be able to do some painting g.
Also, curse you harbor freight for not making your engine stand and engine hoist compatible. I was able to get the engine on the stand with some help.
Pulling the engine from the pull a part took most of my time, will be back tomorrow to grab a wiring harness, ecm, radiator, etc.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You need the correct 4.0 manual spacer plate or your starter isn't going to line up correctly. There is almost 2 inches of difference between the diameters of the flex plate and flywheel used on the 4.0.
Nate.Mountain
3
Idaho Falls, ID
2.9
Home after pulling the engine from the yard
Harbor Freight giving me a headache
After some cleaning
Nate.Mountain
3
Idaho Falls, ID
2.9
Thanks for the heads up adms08. I wonder if that spacer plate can be had at Rockauto? I'm getting my flywheel, clutch, pressure plate, etc from there. There is a 91 4.0 manual explorer at the boneyard I saw today. It should the plate but it would be a bear to get to it.
rangerenthiusiast
2
Hudson Valley, NY
4.0
Mm-hmmm... I’ve never gotten anything from HF that was worth a damn. Most of their tools break the first time you use them. China, China, China...
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Call up your local dealer. Last time I needed one I was able to get it new from Ford, and the price wasn't bad.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I think I have had pretty good luck with their stuff.
But I don't have high expectations of cheap stuff.
Oh. That reminds me, I gotta get the heater turned on in the parts washer.
Nate.Mountain
3
Idaho Falls, ID
2.9
My garage is full of HF stuff to be honest. Just have to be smart shopping there. And have reasonable expectations. I use their impact sockets almost daily. Their Pittsburgh wrenches aren't bad either. I picked up the engine hoist for 90 bucks. Can't beat that. Their 21 gal compressor is pretty nice.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I think that air compressor is my only HF purchase I am truly disappointed in. It didn't keep up with my tools and lasted less than 3 months before locking up.
But I think it may have had issues from day one. I have 100 amp service to my garage, a sub-panel run from the main one in the house, and my wife said that she could tell when it kicked on because the lights in the house would dim. My 220V 60 gallon unit doesn't do that.
Nate.Mountain
3
Idaho Falls, ID
2.9
Made a little progress today. Hit the bone yard and picked up a ECM out of 91 manual explorer. Getting the wiring harness and starter out of the same vehicle. Picked up an alternator, air intake and MAF. Spent some time cleaning up the engine, dang thing was caked in oil. Pulled the plenum and got it ready for paint.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
i suggest to replace the freeze plugs. especially the back ones.
a31ford
Electronics GURU
26
Brandon, Manitoba
2.9
is there an update on this swap ??? very interesting....
Staff online
Shran
April Truck of The Month
