Yeah, I would run the CV's without a second thought for what you have for power. As for the Hi-steer thing, the ZJ DOESN"T have that. It is basically the same as a XJ. The 99 and up Grand (WJ), however, DOES have ALOT to offer. You take the both knuckles, the brakes, and the upper tie rod, and say "hello" to TRUE crossover steering, just like the over priced "kits" that you can buy. The downer is that you need the following parts to make this work, but, if you shop around, it is still cheap: JKS man. has the 1/4" thick weld on spacers that you need to be able to keep you small bolt pattern, as the WJ is a big pattern Chev. Use the rotors ( and hubs) for a 2001 and up TJ Wrangler, brake issue solved. There are also 2 different calipers for the WJ brakes "I said STOP" & "I said stop NOW!". I like the later, as they are 4 piston calipers and about $45 reman. The rotors are also ALOT bigger than the normal D30 brakes.
Your very welcome.No trouble helping someone to do something "lowbuck". I have wheeled the Bejesus out of the D30 in different forms over the years, and have learned ALOT about what works, what doesn't, and most importantly, WHY? I am actually tossing a D30 under my 87 Ranger S-cab, and it is a Disco axle, with v8 power and other goodies. Check the build thread for any tips, or questions that you have. Since I don't have the stupid cast on my left wrist anymore, I can FINALLY get back to working on it.
