Which diff cover???
Which diff cover to use?
  • Total voters
    15
UrbanRedneckKid
17
Cass Co, Missouri
OK, so I've been tossing this back and forth in my head for some time now, as to which diff cover to use.
Clear Gearz cover w/LED inside axle housing.
I've seen testing of this cover and it is way way stronger than it looks, practically unbreakable. And if I had this cover, I plan to light up the inside of the diff with LEDS.
**Can easily check for water contamination after wheelin
**Will clear my steering
Ballistic Fabrication cover
Looks really mean, almost indestructible. Cheaper.
**Very good chance of my tie-rod hitting it while turning.
**1.5" OD tubing tierod-over-knuckle, very minimal clearance with oem cover.
Clear Gearz cover
http://broncograveyard.com/bronco/i-012114_clear_gearz_new_dana_44_front_cover.htm
Ballistic Fab's cover
http://www.ballisticfabrication.com/Dana-44-Differential-Cover-WELDED_p_1594.html
Toreadorranger
5
Sal
RuffstuffSpecialties. All 3/8" cover, great customer service.
Forget the cleargearz cover. They dont break they dent and then the gears dig into the back of the cover, and eventually they break. Stick with a steel cover.
Ballistic Fab makes some nice products. But their customer service and shipping blows.
Doom's Day Custom
5
nj
4.0l
cleargearz cover suck!!!!!
rangerguy1996
ox comes free with locker haha
zukirider21
5
NJ
2.9
x2! lmao
i wish i could afford an ox hahaha...
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Support the vendors, go with Dan's RuffStuff cover...If I hadn't got a smokin deal on a Riddler, I'd have one!
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
My buddy (forums member Grunizzle) has the Ruffstuff cover, it's great but the drain plug was drilled/tapped a bit crooked so it makes it difficult to seal without tearing up the rubber gasket on the plug.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
i know you said you saw testing of the clear gearz, but it looks like if you hit a rock the right way, it'd crack. also, the drain plug looks like it's rubber.....maybe its my screen being too dark. looks like it could be a weak point. however, it would be cool to be able to see your gear oil and know if H20 was in the diff.
as someone else mentioned, i'd go with ruff stuff. i plan on puttin one on my 8.8 as soon as i get it under my BII.
Bray D
2012 UA Ranger
8
Manito, IL
ruffstuff. Support our vendor. I've got one on my D44 front with highsteer and 1.5" tie rod - clears the cover beautifully.
crawlin91
60
Crawlorado
2.9, 4.0
i got a ruffstuff 8.8. Only thing I would add is a drain plug.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Anybody have pictures of a light in a clear diff. cover? I have one for my D30, came with it, and think that would look cool but dont know how to instal a light in it.
Ranger#1
5
lake havasu
x2 suportor of trs and you dont really relise how thick 3/8 is untill you have it in your hand
