What sort of gear do you always carry in your truck?
broncc
566
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
I'm curious where everyone stands with confidence or paranoia in your trucks. I personally keep quite a lot. I have used it all to either get myself home or much more often friends/family home.
Up front I have:
notebook, ear plugs, microfiber, EZ pass, Convoy s2+ with spare batteries, extinguisher
In the trunk I have:
black bag; screw driver, pliers, vise grips, adjustable wrench, box cutter, duct tape, zip ties, spark plug, tire guage, obd2 scanner, hose clamps, mechanics wire, straps, test light, jb weld, jumper cables, inflator, tire patch kit, multimeter, tire caps, fuses, lighter, poncho, space blanket, hand warmers. That along with the socket set, tow straps, tarp, and jack all live in a milk crate. In the trunk cubby I have; bug spray, tire iron, flares.
I have a first aid kit just wedged under the donut holder for now:
tylenol (all used up), motrin, bandaids, gauze, tape, antiseptic, tweezers, wet wipes, clotting pen, gloves.
I have used nearly everything in this kit at least once. I often find myself wanting to reduce the size of my junk because these are only the static, non-personal items that stay in my truck. I have two straps mainly because I don't trust the first one. It has gotten a lot of use and has a lot of dirt inside the fiber. I guess I could just bring that along as a primary when I intend to get stuck and leave the good one in the crate. I need to decide if I want just a test light or the multimeter in my kit. I should not have both but I cannot decide. It might be useful to have some benadryl in the aid kit, but I'm very cramped for space in that dollar store sandwich case. As I finish writing this post I seem to be missing my bottle of sun screen.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
General recovery tools, general wrenching tools, some small spare parts, length of heater hose, gasket sealer, extra fluids (oil, coolant, gear oil, ATF).
A few extra pounds.
cbxer55
767
Midwest City, Oklahoma
Electric tire pump, tire pressure gauge, tubeless tire repair kit and can of Fix-A-Flat and jack. Also gallon bottle of coolant, gallon bottle of h2o, quart of oil and a set of jumper cables. All in a black milk crate zip tied to the passenger side by the tailgate, under a bed cover. Sometimes five gallons of go juice, firmly tied to the driver's side by the tailgate.
Same in my Lightning and Mustang as well.
I've used the tire fixings for other peoples vehicles much more than my own.
Forgot, all three have an 18 inch breaker bar with the appropriate socket for use as a tire iron.
2drxploder
436
usa
ranger
347
lower
235 on 15s
toilet paper.
duct tape and a few tampons (you may laugh but smack one or a few on a bad cut and wrap w/ tape) plus they r sterile!
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
A spare, floor jack, breaker bar with 2” extension & socket. 4-way lug wrench, small box w/tools, jumper cables, tow strap, jump box, extra qt of oil & trans fluid (more so for the power steering than the trans) small bottle of hand cleaner, clean rags & some gloves. Also have some ratchet straps. A couple of hitch drawbars and a set of magnetic base trailer lights. All in a plastic bed box.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Extra beer.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
I was gonna say Yukon 4.56 ratio
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
Small tool kit, couple of screwdrivers, work gloves, zip ties, several tie-downs and bungees, jumper cables, can of ether, tow strap, tow hook, hitch ball. I drilled a 1" hole in each side of a plastic storage tote and hold it in place with a tie-down attached to the front bed hooks.
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
The one bad thing is you can carry every tool to repair whatever fails, but most likely you’ll need parts you dont have with you. But I do it too and sometimes I need to visit the “truck box” to take care of a issue with something else.
ericbphoto
16,598
Wellford, SC
6"
What a question.
in the Fun50 (daily driver )
Tire pressure guage
Pen and paper
Ratchet straps for securing cargo
Drawbar with 2”ball
4-way lug wrench
Air compressor
OEM screw bottle jack
Special socket for lug nuts
If on long trip, my big tool bag with wrenches, sockets, hammer, hack saw, gloves, rags, tire plug kit, etc.
In the Ranger (usually ready for wheeling/camping);
Tire pressure guage
Tire plug kit
Tire deflator kit
First aid kit
Fire extinguisher
Toilet paper
Air compressor (built in )
Pneumatic cutoff tool, recip saw, die grinder and assorted wheels, bits and blades
Big tool bag listed above
Recovery ropes, tree saver, soft and hard shackles
Hi-Lift jack
4”x4” blocks for wheel chocks and cribbing
Small bucket for oil recovery
Funnel
Hatchet
Folding shovel
Pruning saw
Fuses
Electrical tape
Short pieces of rubber hose
Hose clamps
Wire and various crimp connectors
Extra front hub
Front wheel bearings and seals
Red tacky grease
Coolant
Oil, brake fluid, PS fluid, gear oil probably a few other odds and ends
RobbieD
2.9l Mafia
3,453
Georgia
What a question.
Tire pressure guage
Pen and paper
Drawbar with 2”ball
4-way lug wrench
Air compressor
Tire pressure guage
Tire plug kit
Tire deflator kit
First aid kit
Fire extinguisher
Toilet paper
Hi-Lift jack
Funnel
Hatchet
Folding shovel
Pruning saw
Fuses
Electrical tape
Hose clamps
Extra front hub
Red tacky grease
Coolant
No kitchen sink?
ericbphoto
16,598
Wellford, SC
6"
Arthur Moss
4
Raleigh, North Carolina
I always have some simple things: a bottle of drinking water, a blanket, a flashlight, and matches.
I also have a sharp knife, a minimal set of tools (hammer, screwdrivers, pliers, etc.), a first aid kit, a fire extinguisher, wires to start the engine, a tow rope, a bottle of windshield wiper.
If it's winter then I also take a shovel and a windshield scraper.
