What radiator for 2.3T?
fix_or_repair_daily
SW PA
Ford,Chevy,Satu
2.3, 5.7, 1.9
Hi, what radiator is everyone else using on their rig? My stock one on my '84 is not cutting it and I wondered if there is a cheap and or easy upgrade. Any help would be appreciated.
Thanks,
Josh
Mutant Pony
9
Hersey, Mi
2300
The hose location on a 2.3 is the same as a sbc, which is the opposite of all other Fords. There are MANY aftermarket, all aluminum radiators out there for for sbc's. You just need one that will fit the space and make some mounts.
Davis
8
Long Beach, CA
you can run a 2.9 or 4.0 radiator with the 88 2.9l ranger upper hose and the lower from an 88 tbird or mustang 2.3. at least that's what i did on my ranger.
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
I've got the 2.25" thick heavy duty unit from the auto 4.0 explorer. The hose locations are opposite the engine but that's nothing some crafty hose splicing cant fix. Otherwise it just bolts in. My coolant temp has never gotten above 185 (even when it was 100 out) with that radiator in there.
red85
7
Kitchener, Ontario, CANADA
306 ci
^hmmm that's a good plan. I have a spare 4.0 HD rad here. I think I know what's going in my 94 turbo swap now.
Turbo-T
Vancouver,Wa
2.3Turbo
I'm running the original radiator in my '84 4X4. Haven't had a bit of trouble with it.
fix_or_repair_daily
SW PA
Ford,Chevy,Satu
2.3, 5.7, 1.9
Thanks guys, got a 4.0 HD radiator fron the junk yard and started putting it in today. Now I just have to get an electric fan and the thermostat to controll it.
Josh
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Frankly in a ranger I'd run a mechanical fan.
Ever hear the saying:
"It's stupid, simple AND IT WORKS, which means that mabey it ain't so stupid after all?"
It is an extension of the "K.I.S.S." principle
AD
