ericbphoto
Overlander in development
16,750
Wellford, SC
6"
I work until midnight... and they need the truck for a paving job in the morning. (It’s an International 7600 tri-axle dump truck.) I’ve got about 6 hours to fix 1 wire.
Ugh. Thought it was an international due to that shade of yellow paint.
Jazzer
458
Indianapolis
Liquid electrical “tape” is your friend.......
-Jazzer
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
-Jazzer
The “green wire” term means the copper already started corroding. These trucks get used for paving in the summer and salting/plowing in the winter. The salt destroys everything in its path. If I don’t cut that section out and replace it, it won’t make it 6 months before I’m in here again...
Fix it right, fix it once.
Jazzer
458
Indianapolis
Sorry, didn’t see that.
-Jazzer
mtnrgr
765
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Drove my ranger today after 2 weeks, and had discount tire put on new tires.
Rick W
TRS 25th Anniversary
4,054
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Did I ever mention I LOVE Craigslist!!
I scored nine 12’ 1x1x1/16” aluminum angle for $75. I think it’s the last thing I need for all my light bars and racks and what not for the two rangers.
Now all I need is for Kirk to transport all the lawyers and judges into a parallel universe where they can suffer like they were in hell for eternity, so I have some time to tinker!
scotts90ranger
4,499
Dayton Oregon
2.3 Turbo
Fired up the auxiliary air compressor(not the good garage one, this one leaks bad and the pressure switch is set at maybe 100psi...) to blow out any debris from inside the cam from running a tap down the middle, then used a can of brake clean to get most of the goo off the front of the engine... then called it for the night... I'll locate some thread tape tomorrow and get the cam seal changed then get the cam pulley back on then timing belt and so forth...
snoranger
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
In case anyone was wondering...
I unbolted and lifted the back of the cab 6”, removed the steps, climbed in between the cab and the frame, I cut about a dozen zip ties, removed the doghouse, pull the harness up to the bottom of the cab, secured with a bungee cord, and removed the wire loom. Now it’s easy to get to.
58193
There were two copper strands left intact before I pulled the harness up. I guess that’s why the short finder couldn’t pinpoint the exact spot.... Whatever, I got it fixed and back together for road dept to break it again tomorrow.
sgtsandman
Aircraft Fuel Tank Diver
12,797
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Installed the roof racks on the 2011. I need to stop by the Home Depot for some lumber.
Roert42
5,035
Kintersville, PA
Ranger XLT
4.0 SOHC
At least you found it. Go home. Have a beer. Relax. Then fix it tomorrow.
I spent 36 hours trying to fix a machine at work this past weekend. Didn't have the fuses in stock. Spare VFD (fancy electrical doohickey that controls an electric motor) was ordered without the proprietary firmware installed and I didn't have the software on my laptop to transfer it from the old VFD. The whole adventure was horrible. Will find out tomorrow if they got a VFD specialist in to fix it yet. We just didn't have the tools or parts. Otherwise, we're going to upgrade the machine with newer VFD's because the old ones are obsolete. Meanwhile, running the system on a "rigged" backup plan.
Sounds like all of my customers.
Roert42
5,035
Kintersville, PA
Ranger XLT
4.0 SOHC
Rick,
What kind of Fuel mileage do you get on the diesel? There is one near me, nearly identical to yours, but with a manual.
I would like another full size truck with a manual, but my last one had a 300 and got around 18 mpg. I hear a lot of good things about the 7.3, but I'm not going to daily a truck that get 10 mpg.
Jazzer
458
Indianapolis
Four or five times a year, I charge my batteries overnight with a 2 amp charge. This morning my six month old Duracell wouldn’t come up past 12.37v, so I exchanged it, swapping it out in Sam’s Club (where I bought it) parking lot to avoid extra trips.
-Jazzer
Rick W
4,054
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Rick,
First, let me say the only time I ever checked it was on long trips: ATL to Dallas, ATL to NYC. On those trips, 900-1,000 miles, usually late afternoon to early morning to avoid traffic in the cities inbetween, I got 19-20. BUTTT, that’s riding with cruise on and maybe 3-4 short distance stops for food, fuel and/or rest stop. Probably at the top of what they can do, standard on cruise should get 1-2mpg more.
But that’s not day to day reality. I’m pretty sure it’s around 15-16 around town & remember diesel is more expensive cause of all the taxes. My truck is completely stock, maybe some wind resistance from the light bars, and I go 75-80 on the interstate all the time. I also have 285/75-16 mild mud terrain tires. I don’t think they’re significantly different diameter than the stock tires, but they’re wider.
I don’t have to work with mine like a lot of you guys do, and I have joked, but this truck has literally been pampered. It was dealer maintained for the first 20 years, at a dealership where I was personal friends with the owner. And I’m meticulous about the routine maintenance.
When I am not using it, I always keep it on a smart trickle charger that helps clean the plates in the batteries. The second I think the batteries might be getting tired, I put in a new set, and I’ll use the used batteries in my town cars or whatever. I buy my filters and routine parts through rock auto or eBay and always keep spares. I can find the fuel filters for five or six dollars online if you can wait a couple weeks to get them, and they’re $30-$50 locally. It’s a no brainer to keep one or two on the shelf.
I’ve always had a full-size truck, and of course I like this one because of the prestige that goes with it, but remember I’m a three-piece suit guy. I got my automotive juices from my different cars.
I think you have to consider what you really need it for, versus how much you want it because it’s cool. The diesel is definitely less maintenance than a gas engine. Forget about going fast off the line, it’s just not what it was made for. If you soup it up to go faster, you will kill your power, you might kill the longevity, and you’ll certainly kill your mileage. One thing nice about the mileage is it is pretty much the same whether you’re empty or if you have another F250 in the back of it. The torque pulls without much more fuel almost regardless of the load.
If you keep it clean with Seabreeze and you do the routine maintenance, there isn’t much trouble starting it down to 20-25° When I visit my kids up north, I put a little gasoline in a spray bottle and I use it like ether, always starts, but of course carrying that around is a little dangerous, I keep it in a thermos.
& mine is the true HD, bought it new at the end of 95. It’s my understanding there were three different F250s in 95/96/97, gray area. There was the 95 carryover, and then apparently there are a handful of light F250s that were made with the flared out 96/97 F150 body line, but they just didn’t sell. That’s when they came up with the HD with the 95 body but it was a 96, but it was a much heavier duty truck. That’s what I have. You can figure out which one it is by the engine code in the VIN, but I don’t know it off hand.
Not sure what else to say, but I’m happy to answer questions, but I don’t think it’s a truck you would get purely for mileage. It will do much more, pull bigger trailers, etc. It’s a much more rugged truck. People will argue with that, but I’ve had them all personally or in my companies. It’s just a workhorse, it doesn’t get unreasonable mileage, but it’s far from economical.
Does that make any sense? I hope it helps!
Roert42
5,035
Kintersville, PA
Ranger XLT
4.0 SOHC
Makes perfect sense. Mileage is more or less on par with my rangers/ old F-150. Wanted something more robust then the ranger, without getting myself into something that was going to kill me on gas. I run 93 in the ranger so price is pretty similar anyway.
Rick W
4,054
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
I’m always long-winded, but I guess my underlying thought is that if it is very well-maintained, probably 15 around town and 19 on the highway is realistic.
As regards using 93, just like the claims of diesel mileage, there are a lot of myths and stories out there. When we talk about mileage, we’re not really interested in miles per gallon, we’re interested in dollars per mile. Unless you’ve done something to your engine, it should run perfectly fine on the cheap stuff. While it might get a touch more mileage on the 93, it’s usually not justified in the additional price. Premium is usually 10 or 15% higher in price, but rarely yields more than 2 or 3% more mileage.
At least that’s what my CPAs were telling me when we were running 300 trucks…
As always, my two cents, hope it helps
Send a couple pictures of the truck you’re thinking about, including a picture under the hood, and tell me how many miles on it, and if it’s got any rust
