2drxploder
436
usa
ranger
347
lower
235 on 15s
cut the drivers seat down, then played around with a full length console from expo, some sawzall modifications later, i still dont like it. t5 shifter makes things difficult. it sounds bad, but i need cup holders, and a comfy armrest, a spot to place my phone wouldn't be too bad either. need a solution fast. also looking for recommendations for carpet replacement 99 reg cab
Rick W
3,912
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Cut seat down how? Can you send a pic of that?
Rick W
3,912
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Well, the vibration should have been worse first thing because at 19*, the water would be frozen. Locking the hubs should have zero effect on that. Had no real vibration until I rotated tires, then I found the bad wheel bearings on the right front and replaced. Vibration has randomly come and gone since
Understood, but I’m not talking about any quantity of water. If you have like a tablespoon, water is heavy and will throw it out of balance a little, certainly enough to feel a vibration. On some tires, even that tiny amount of moisture can settle into the rubber structure. Even if it’s 19° out or less, once you start rolling and flexing that rubber, the rubber that gets bent with the rotation will warm up pretty quick and drive that moisture off.
I’m absolutely not trying to say I’m right or I’m smarter or anything like that, just trying to help you with your issue.
QUICK EDIT: Maybe you could try swapping the spare on each corner one by one to isolate which tire is giving you the shake.
and I was thinking about the locking hub thing. When you lock the hub, doesn’t that increase the mass of the rotating everything? Wouldn’t that tend to dampen a vibration?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You chop the stupid side part "middle seat" off the driver's seat to make them true bucket seats so you can add a real center console.
Rick W
3,912
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
@Dirtman
Okay, thanks. I was thinking “cutting down” the seat lower or to slide it further back. Looking for more space behind the wheel.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
@Dirtman
You have to trim your legs for that...
17,879
SW Iowa
Started mocking up sliders tonight.
Rick W
3,912
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
🤔. Hmmmm....
All three, or can I just tuck the middle one in my sock like usual?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Roert42
4,985
Kintersville, PA
Ranger XLT
4.0 SOHC
🤔. Hmmmm....
May need to slide it under the seat, otherwise it might get stuck under the brake.
17,879
SW Iowa
scotts90ranger
4,376
Dayton Oregon
2.3 Turbo
Finally started digging into the oil leaks on the '90, I'm pretty sure the whole problem is a leaking cam bolt... considering there was oil SITTING in the back side of the cam pulley against the guide washer thing... the cam seal is filthy so it's probably not leaking but I'm going to change it anyway since I'm there...
All this time and it's a leaky bolt... I put thread sealant on it before apparently but must not have been enough? I think I'll try to find a 12mm by 1.75mm set screw and plug the thing deeper...
Stupid engine making good oil pressure... if it was a SBC it wouldn't make enough oil pressure to have this problem :), but then again those don't have hollow cams...
lil_Blue_Ford
6,136
Butler, PA, USSA
4.9L
That’s just the thing, I sometimes get vibration cold, and sometimes warm. Doesn’t make sense. Also was getting vibration yesterday but it seemed to go away between 45 and 60 mph, but would come back worse at 65 than at low speed. Feel reasonably certain it’s the right front that’s the problem but that’s the one with the new bearings that I can’t find anything loose in. Bout to get pissed and redo the front, just put new everything in... bearings, ball joints, tie rods, bushings, shocks.... really wanted to get my green Ranger done before tearing into something like that.
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
did you check the rotor for runout?
take a real good look at the tire for run out?
