Valvoline VPS Oil Cleaner
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
So this stuff is back on Ebay after a bit of hiatus, and for a reasonable $13. But it only offers a $14.15 expedited shipping option! Is this stuff normally in the $20's? and they're trying to lure people by making up their cost via shipping charges?
I've looked around a bit and can't seem to find it offered anywhere else though, where else do you get this stuff?
I'd like to give my GMC and my Saturn SL a run through next oil change. I saw some pictures here on TRS a while back and was pretty impressed.
http://www.ebay.com/itm/VALVOLINE-VPS-COMPLETE-OIL-SYSTEM-CLEANER-1-GAL-SOLVENT-FREE-PROFESSIONAL-USE-/331843787689?hash=item4d436e5ba9:g:jCwAAOSwlHRXI2u7&vxp=mtr
8,372
Valvoline Professional Series(VPS) oil cleaner(flush) uses chemicals not allowed for residential use, i.e. kills the fish and the puppies, lol.
Which is why you don't see it at local Auto Parts stores
A gallon is 8lbs so heavy to ship
Captain Ledd
39
Michigan
302, 2.3
I use flush all the time, basically every oil change. Usually Gunk (Walmart - Oil supplies is about the only thing I buy there) or Motor Medic (AutoZone brand).
But my GMC is used, So I'd like to run some through it. And the last oil change I did on my SL had a chunk of paper-like material stuck to the dipstick, but I didn't find any in the old oil. Probably won't get any paper out, but I'd like to try and clean out anything else that is in there.
I was under the understanding this was a special oil concoction, where you drain everything, fill it back up with this, run it for ~10min, and drain again.
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've always run a quart of ATF for a 100 miles or so before changing the oil on a new to me car. I figure the detergents will help clean any varnish or gunge from lack of maintenance.
I have used the Valvoline VPS kit before. Your understanding is basically correct. It is 4 qts of a 0-20 oil with a super concentrated detergent in the oil. You drain, change the filter, and fill. Top it off with the thinnest stuff you can get if your engine takes more than 4 quarts, then let it run for 10 minutes and it cleans everything.
The Valvoline rep did say not to use it on high-mile engines unless you know the service history and that the oil changes have been kept up with.
As for why it comes and goes. I bet Valvoline doesn't want the general public having full time access to their professional line.
Captain Ledd
39
Michigan
302, 2.3
The GMC supposedly has maybe 125k on a rebuild (allegedly rebuilt), looks pretty varnish-y through the valve covers but doesn't appear that there's any trace of sludge or other buildup. Of course I've had 2 or 3 flushes through it since I've owned it.
I do have a few quarts of Chrysler ATF +4 left over, maybe I'll throw one of those in for the next oil change.
