Tucking 33's
jkeckss
Saskatchewan
What company is that in Cali? Glassworks? Thats the best price I have seen so far, shipping for most was more than the fenders :shok:
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
McNeil Offroad, Chad was the owner.... Most of the fiber glass companies out there are owned by the McNeil family.
jkeckss
Saskatchewan
Sweet thanks.
Does anyone have pics of a truck with fiberglass that has the stock width stance? I am curious to see how ridiculous it will look in between installing the fenders and getting the long travel kit that widens it. They suggested 6 inch fenders, but any pics are good.
Thanks in advance if you can find any, I have looked for a long time and found nothing.
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
This is with 4" fenders, a stock width diff and 10" rims/13.50 wide tires, not a great pic but it works.
jkeckss
Saskatchewan
So based on that pic, which looks like your tires are close to flush if not a bit wider, if I went with 6 inch ones, stock rims and something like 11.5 inch wide tires, the fenders would stick out like, what, 2-3 inches? That might not look bad, might look odd tho. :dunno:
If I went with 3' wider fenders and 11.5" wide tires, it wouldn't look bad I imagine. But if I switch to the long travel kit later I will likely need to buy new glass again.
All that based on the assumption that my 07 would behave relatively the same as your straight axle width-wise....
hmmmmm..... ugh decisions :annoyed:
Suggestions anyone? based on this info
06RangerXLT
54
Georgetown Ontario
heres 8" rim with a 4" offset, (3.75 stock) and i have spindles that widen 1" per side. i have stock fenders. 6" fenders on stock rims will look strange IMHO. also, long travel kits cant use stock rims as they wont clear the upper uniball. dixon bros mentioned that to me when i was shopping for my friends 2008 4x4.
heres 8" rim with a 4" offset, (3.75 stock) and i have spindles that widen 1" per side. tires are 32X11.50R15. i have stock fenders. i'll be running 3" come spring time, winter will just beat them up. I'll be ordering from McNeil.
jkeckss
Saskatchewan
I talked to McNeil, they suggested that I deal with a company in BC called BC supertrucks, price was quite a bit better than from McNeil just because shipping is lower. Check them out.
:headbang:
Justin
colby450xc
Kansas City Missouri
You could also bulge your bedsides yourself for damn near free.
jkeckss
Saskatchewan
Have you tried that? Is there a tech article on how to go about it?
I have the FX4 with the stock flares on it which is why I wasnt gonna try that but if I plan on replacing them anyway I could give it a try I suppose.
colby450xc
I did it on my 93 fleetside. Its pretty easy to do. I'm not sure if the flares will still fit properly after the fender is pulled out. It might leave gaps on places. Pulling them yourself will not come out with the same shape as if you bought the fiberglass fenders, but it would make it so wider wheels and tires would tuck inside the bedsides.
You might check to see how the flares are mounted also in-case they wont fit right afterwards. I wanted to take my stock flares off to paint them. I figured they just used the plastic push pins and double sided tape, I was wrong. They have bolts also, and I would have to remove the fender liner and all the screws are rusted to hell so I said to hell with it. :annoyed:
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
