Transmission Crossmember Bracket
dtg_xc
Springville, IN
Ford Bronco II
Hello,
I'm looking for transmission crossmember brackets for a 1988 ford Bronco 2. Mine is rusted out. It is the part that connects the crossmember to the frame. I have searched all over the internet and don't know where to find them. Anything helps! Thank you!
Junk Collector
Truck of Month
4,858
Rapid City SD
Are you looking for the style that has round rubber bushings on either end of the crossmember? If so you are better off finding just the crossmember itself from a newer truck at a junkyard. '90 or later Ranger or Explorer would work. Very easy swap, you just remove both of the brackets from your frame and bolt the new crossmember in place, may have to drill a hole or two.
dtg_xc
Springville, IN
Ford Bronco II
That sounds correct. I found the part on Parts.rockwallford.com but it has been discontinued. the part # is E5TZ-6096-A
Junk Collector
Truck of Month
4,858
Rapid City SD
The newer style is the easy replacement option for you then. What you want is the bottom one in this pic:
dtg_xc
Springville, IN
Ford Bronco II
I believe it is the middle cross member. I don't have a picture at the moment, but I need the actual bracket that connects that bushing on both ends to the frame. Don't necessarily need an all new crossmember, but the brackets on both ends.
Junk Collector
Truck of Month
4,858
Rapid City SD
Yeah, I know exactly what you are looking for. I just don't think they exist as a new part that you can buy - if you want to keep your current crossmember, you will need to fabricate new brackets or find some in a junkyard. It is just easier to dump that mess completely and use the newer style crossmember.
dtg_xc
Springville, IN
Ford Bronco II
Ahh, I understand what you are saying. Is it a direct swap to that style cross member? Looks like that one bolts to the outside of one framerail, and to the bottom sid of the other, where as my current one bolts to the outside of both frame rails (I believe). What years are those crossmembers in?
Junk Collector
Truck of Month
4,858
Rapid City SD
Yes, you just remove your old crossmember brackets and bolt the newer style in place. IIRC some of the holes line up but not all of them so you may have to drill one or two new ones. The newer style sits outside of the frame on one side and up inside the frame on the other.
You would find the newer style in 1990 and newer Rangers and Explorers. I don't know if it was used past 1998, I assume so, but I haven't worked on anything newer than that yet.
dtg_xc
Springville, IN
Ford Bronco II
Great thank you. Ill see if i can find one somewhere. I found these online, they are not OEM, but Can you tell if they would work?
Junk Collector
Truck of Month
4,858
Rapid City SD
I am not sure I'd trust a simple flat piece like that in the long run, no matter how thick it is. It is not very rigid. The factory style is designed so that it cannot flex. Maybe I am overthinking it.
2 bronco 11s
66
kentucky
ford bronco 11
If it's an 88 , remove the right bracket off the frame, the left has a hole in the frame for the only bolt . Right side will bolt in the 3 holes from the old mount.
svtcards
137
Lyman maine
302
3'' front 4''back
I used that exact cross member on my t5 v8 swap.Work perfectly.The ricks rangers member.not the other 1.
svtcards
137
Lyman maine
302
3'' front 4''back
I'm pretty sure it ll work with whatever trans u have in your bronco ii.Just as long bronco ii's use same trans as the regular rangers do
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
I have a donor 88 post a pic of the mount you need and I will look if it's the same.
