tranny bellhousing torque specs
ray115
1997 4.0 v6 for
trying to figure out the torque specs on the bolts right behind the bellhousing which hold the bearings and shaft. 1997 ford ranger 4.0 v6 4ald tranny i believe
Wait, do you want specs for the torx bolts in the pump, or the bolts that hold the bell to the case?
ray115
1997 4.0 v6 for
No i know the bolts that hold the bellhousing on are 40 the bakck of the bellhousing that is around the bearing i am curious about
ray115
1997 4.0 v6 for
I believe there are 6 bolts
ray115
1997 4.0 v6 for
Geeze. You kids need to learn some patience.
First, you have a 5R55E, not an A4LD. A4LD was discontinued in 1994.
Now, for your torque specs. Tighten in a star pattern to 16-21 ft-lbs.
ray115
1997 4.0 v6 for
Thanks man appreciate it
Richard H
Ferndale
Ford ranger
Hey all just asking a question on torque specs for a manual transmission reinstall
