Torx and Torx Plus
8,370
Its one of those things you know but forget to pass along
Ford uses torx plus in a few applications, seats and seat belts often
Here's the difference: https://www.pemnet.com/images/design_info/torx_vs_torxplus.jpg
If your regular torx feels sloppy and next size up is too big then its most likely a torx plus head you are dealing with
Torx plus bits/sockets often have to be ordered online as most local stores don't carry them
So if you are looking for tools you will rarely need but must have, these are a good ones :)
Seat belts are usually T55 Plus, just FYI
And most sets only go up to T50 plus
97RangerXLT
3,941
Fishers, IN
2"
31"
Thanks Ron, did not know there was a torx plus...
AJ
17,838
SW Iowa
Fun fact: The "Bronco Bolts" factory added to install misc accessories all over the new Ford Bronco are Torx Plus and not regular Torx.
So yay I get to buy more tools! Countered with BOOO! because they are boring and very similar while incompatable with the many Torx tools I already have...
ekrampitzjr
1,067
Virginia
Thanks for this. I wonder if a security version of Torx Plus is in use. On regular Torx, that's the one with the little pin in the center to keep you from loosening with a standard Torx driver. Finding the security bits used to be a pain, but they're widely available now.
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i just knocked the pin out of those security ones. jeep used those a lot.
i never knew about torx plus though
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Not terribly secure anymore. Is it?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I fairly recently discovered torx plus. If you look closely the splines are slightly different (tapered tip) and beefier. Alot of torx bolt on my F150 are torx plus. And yes, its hard to find sets. My local auto parts stores have decent cheapo tool aisle. No sets, but I was able to find some individual TP sockets (like a TP55).
ericbphoto
16,598
Wellford, SC
6"
That’s what is shown in the picture in the link above
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Around here 9 out of 10 would look at that pic for 1/2 sec and call it a torx. Maybe I am surrounded by short attention spans, or idiots...
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
External Torx Plus sockets common as well?
ericbphoto
16,598
Wellford, SC
6"
SenorNoob
567
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
So is Torx+ an upgrade in torque handling? Or just an excuse to change drivers again?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Torx is great but I have had bits break on me from time to time. Maybe this is an attempt to address the snapping issue?
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Anyone else remember Posi Drive screws?
Of course I had to buy the screw driver that matched my set... It may have been a GM thing. Probably been used a couple times.
I think that was a thing just prior to introducing Torx drive fasteners.
