Timing cover potential for ruining Oil pan gasket
Josh B
1,988
Oklahoma
Lightened it up a bit. That pan sticks out there a ways
Ede
10
USA
Ford / Ranger
Well, took off the harmonic balancer and timing cover. The cover did not want to release with the 2 front oil pan bolts so I also removed two more which in hindsight probably didn’t do much to help. I gently pried and the oil pan gasket definitely wanted to stick. I rotated the pan as it held in place and used my plastic putty scraper to help keep the pan gasket from tearing off which seemed to help. However, according to YouTuber Ford Tech Makuloco, if you have a tan, floppy oil pan gasket instead of the rigid style, you gotta replace it. Also noticed on the rear pan bolt, an o ring seal broke. 😞
Looks like the according to the maual, I will have to lift the engine it to replace the oil pan gasket. Just got to figure out a way to do that. 😂 Hope I didn’t bite off more than I can chew and that I can get this all back together, running again!
Ede
10
USA
Ford / Ranger
Josh B
1,988
Oklahoma
Got a welder?? Uhmm, nevermind
Can you do carpenter work?
I believe you could build one of those fender ledge lifts with a few ground treated 2x4's and some treated plywood. Those kind are much more durable and rugged than plain pine framing stuff.
If you do that make sure to keep your hands and fingers out from under any part of it
Part 2. It's still hooked to the transmission also, that could be a whole nuther can of worms :/
  • Like
Reactions: Ede
Josh B
1,988
Oklahoma
Have you already considered the possibility of buying, borrowing, or renting a decent engine lift ?
  • Like
Reactions: Ede
Ede
10
USA
Ford / Ranger
Looking into renting or borrowing one. Someone who has recently done his pan gasket is trying to dissuade me from doing my pan gasket since it didn’t tear (hopefully). He said the job truly sucks without a lift. 🤔🥹 😢
Ede
10
USA
Ford / Ranger
That is an option.
Junk Collector
Truck of Month
4,874
Rapid City SD
Everyone's definitely of "sucks" is really subjective, a clutch job on a Ranger is one good example that many people really complain about but I am good enough at them now that I can knock one out by 8PM if I start at 5 right after I get off work. If you don't have to pull the transmission to get the oil pan out, it can't be that bad!
I did a pan gasket on a 2.3 years ago with the engine in the truck and it wasn't too bad (trans removed, of course.) The worst part was getting the dipstick caught between the pan and block and cracking the pan because I wasn't aware that it was there. THAT sucked.
Josh B
1,988
Oklahoma
Awesome man :)
  • Like
Reactions: Ede
Josh B
1,988
Oklahoma
Looks like it was intended to work, whether it will or not is yet to be disclosed.
Reminds me of that old ad in the newspaper, "Hang Glider, Cheap!, used one time, slightly damaged. Saint Thomas Hospital, Room 204"
  • Like
Reactions: Ede
Josh B
1,988
Oklahoma
It really needs another angle or two. To the right in that photo it appears jumbled, or maybe something beyond is mixed in tho not part of the rig?
If it looks nothing's broke or amiss in person I'd take a shot I believe
$50 really won't buy a lot these days, I stuck almost 50 into a cheap bag of dog food the other day, and it wasn't even my dog
If you can get something that's ready to go for 50 that's quite a deal. One piece of plywood to start building one up would cost that
Ede
10
USA
Ford / Ranger
Well, I picked it up today. Looks like these supports/hoists were sold around 1998 and made from heavy wall tubing. The weakest link appears to be the come along weld, although they are rated for 500 lbs. I can see why the newer ones don’t use come alongs and just use spider handles on threaded rod. Mine has an attachments for a holding device that is threaded which I will use as safety before going under the vehicle. Also has an accessory offset bar attachment for increased stability transmission support. Overall I think it will work and since it was on offer up, paid only $35.
Josh B
1,988
Oklahoma
Awesome man, you came out like a bandit on that. It looks better than any of the others I've been seeing, and likely built better. A year in manufacturing days can be worlds away in design, materials, and workmanship.
Hek, i'll give you 40 for it right now! :D
  • Like
Reactions: Ede
Josh B
1,988
Oklahoma
What does that "holding device", "J" do? I think on some of those cheapies and home made there was somthing like that for lifting it
  • Like
Reactions: Ede
