Throttle Cable
Pokey427
Lyman, SC
Ford Ranger 4x4
I need some help locating a replacement throttle cable for my 1990 Ranger with the 4.0L. Apparently there are two cables, and one malfunctioned several years ago and left me stranded. Towed to the Ford dealership and their "fix" was to cut the cable with some wire cutters and leave it with just the one cable. At that time they advised that they could not order a replacement cable, and the service manual did not have a work around. Well now my second cable has broken and the shop cannot locate a replacement. They are trying to locate a generic cable that maybe can be modified, but so far no luck. Ideas, or suggestions where I can get a replacement? I'm stuck. Thank you
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,955
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
What about cable used for bicycles? Swedge the one end with the appropriate end and cut to length and swedge on the other. Depending on the cable ends used, you might be able to use the existing end and just work with the other one.
8,375
Welcome to TRS :)
There is only 1 "throttle cable" for the gas pedal
There can be a 2nd "Cruise Control cable" attached to the throttle linkage
Picture here of a single cable hook up, no cruise control: https://www.ranger-forums.com/attachments/4-0l-ohv-sohc-v6-tech-33/217528d1683053137-throttle-cable-throttle-body-how-do-i-remove-bpwggok.jpg
Picture here of the 2 cable hookup, with cruise control: https://www.ranger-forums.com/attachments/general-ford-ranger-discussion-15/178785d1501427520-how-do-you-remove-throttle-cable-p7190004.jpg
The end of one cable is broken, obviously, lol
What broke on your 1990 4.0l Ranger the first time?
Was it the cable itself, like in the picture?
Or was it the throttle linkage, the connection to hook up the end of the cable?
Ford dealer would have had, or been able to get a new gas pedal throttle cable, they are still available, F1TZ-9A758-F
Pokey427
Lyman, SC
Ford Ranger 4x4
I'm sure you are correct. I don't spend much time under the hood of this vehicle so i may not be accurately describing, but the first time, the cruise control cable got stuck and they had to cut a cable. Now I have in the shop because it lost complete power. Engine starts and runs, but no power. Shop advised that the "throttle cable" broke. Thank you for the gas pedal throttle cable part number. I will see if this is what they are looking for. Thanks once again for the help.
Pokey427
Lyman, SC
Ford Ranger 4x4
Still no luck. The part number provided by RonD does not fit a 1990 Ranger 4.0L according to all I can find on the internet.
NTSB issued a recall #89V234000 Dec 11, 1989 for sticking throttle cables on this vehicle with this motor. The fix was a revised air inlet tube to increase the throttle lever-to-inlet tube clearance. But I cannot find part numbers for anything. But for now, I just need to find a replacement throttle cable that fits the 1990 4.0L Ranger. Again, any generic cable suggestions that might be modified may help. Thank you
8,375
Odd F1TZ-9A758-F won't work, listed for 1991-1994 4.0l, 1990 was the 1st year for Rangers with 4.0l, as far as I know Ford used the same throttle body, 1990-1994, probably thru 2000
The NTSB was for the Air Inlet Tube, not throttle body, its the larger black plastic tube that runs from air cleaner box to the top/front of the intake/upper engine
Do you know what part of the throttle cable broke?
