oddball101
- Jun 8, 2010
- 0
- Columbia SC
- Ranger
- Engine Size
- 5.0
Ya, so I feel a bit stupid. I went into it this weekend. Got the wheels off, passenger side wheel well liner out, collectors disconnected and started backing out bolts on the passenger side when I remembered I had to undo the EGR pipe as well. When I grabbed the pipe, I found that a hose had popped off..
So instead of going through and redoing everything like I had planned, I simply just buttoned everything back up. On the test drive everything was good to go, no leaks. So basically, I made a ton of work for myself thinking I messed something up when in fact, I did just fine. Turns out the hose is no longer gripping as tightly and needs replaced. I can live with that.
I am pretty sure I said I'd get pics of the heat shielding I picked up from another 5.0 explorer in the JY when I got back into it.
This is the actual fiberglass heat shield that is molded perfectly to the AC box. The two holes circled in red are where the layered aluminum sheet attaches. I picked up two of these shield castings as the one in my hand is actually broken at the bottom, but otherwise serves its purpose for pictures sake.
A side shot to see the type of fiberglass layering used. Unfortunately I do not have a shot of the aluminum sheet by itself. I will say though, that it is a substantial piece and if you could get it off without breaking it, it is worth the install effort.
The red is the molded "cast-like" fiberglass piece that isn't broken and I have added metal tape in areas to reduce fraying of the edges. Still have a little more to do. The blue is the moldable aluminum fiberglass sheet . It reinforces protection of the lower AC box area as well as the pipe.
The blue is the underside where the aluminum fiberglass sheet can be molded under the box. I put it on there for the added protection, but I do think it is only a 16th" off of the header.
