The Great American Classic
-Nate
56
Sunny So. Cal. Land Of The Weird
Ford Ranger XL
2.5 (4 Cylinder)
Nothing is so difficult it cannot be overcome by brute force and ignorance =8-)
So, that's what it is .
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
You can see the helical cut gear on the end, it meshes up with one on the cam that is behind the large timing gear.
-Nate
56
Ford Ranger XL
2.5 (4 Cylinder)
Indeed I can and why I thought it might be a mechanical breather......
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
Running out of parts to put on. :)
Brother is coming over next weekend to help to the car back together, maybe we’ll even place the engine.
-Nate
56
Ford Ranger XL
2.5 (4 Cylinder)
Nice ! .
The rain took the day off so I out the rebuilt engine into my 1959 VW Beetle and got it running, almost ready to drive .
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
No pictures, but I finished up a couple more odds and ends. Valve covers are painted, brake booster is back on, power steering rack is bolted on.
I broke two of the original bolts to hold on the valve covers, so I decided to replace all the bolts.
I need to drag the trans mission out from under the table and get that ready to go back on the engine. Then I should be able to put them in the car.
-Nate
56
Ford Ranger XL
2.5 (4 Cylinder)
I can't wait to see it finished .
I hope you know how to attach a video of it running .
I only had one dry day but I got the engine in and running, the brakes are soft so I'll sort that out before any test drives .
Isn't it fun knowing you're almost there ? .
=:cool:
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
last weekend I got the trans all cleaned up and mounted to the engine. Pushed the car out of the garage. Then rigged up my chain hoist.
Brother was supposed to come over this weekend to help get it in the car, but he was sick. Maybe next weekend.
-Nate
56
Ford Ranger XL
2.5 (4 Cylinder)
I hope you replaced the clutch release donut .
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
New throw out bearing, clutch fork and pivot ball.
There was only about 30k on the whole transmission rebuild when I pulled the motor, but the pivot for the clutch fork was worn out and everything chattered and squeaked a lot.
-Nate
56
Ford Ranger XL
2.5 (4 Cylinder)
I hate clutch judder .
I have found that -some- vehicles tend to have very long clutch cover life in spite of needing new clutch discs occasionally .
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
The reality is, I should have replaced the pivot and fork when I had it apart before, but I didn't because I was in a hurry. I did the rebuild in a weekend in someone else's driveway. Didn't want to leave it there for a couple weeks waiting for parts.
It was really annoying so now is the time.
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
No pictures.
Brother came over.
Got the engine and trans bolted up. Started the wiring. ( I thought I did a good job labeling everything, but clearly I was drunk.)
All the accessories are in.
Still a ways to go,“WTF is this and where does it go?”, but we’re pretty close.
It’s still a giant pos but it’s my giant pos, and I am itching to get it back in the road.
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
Put the upper intake on and plugged in some wires and hoses.
Looks like just some odds and ends at this point. Could probably get it running in a weekend if I put myself to it.
-Nate
56
Ford Ranger XL
2.5 (4 Cylinder)
Thanx for the update ! .
This sire seems moribund .
My little Ranger now has a whopping 137,000 miles on it and still runs like new with 40 degree A/C out the dash vents .
I can't wait to read about your test drive .
