The cast iron thread
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Nice, but do you pronounce it “I-Ron” or “I-Ern”? I recently heard someone pronounce it “I-Ron”... That was just strange.
Do you say WA-TER, WA-DER or WOOD-ER?
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Wa-der.
I recently noticed my daughter say orange as or-ange... I’ve made a point to listen closely and it seems most people say ar-ange. (at least around here, it may be different in other parts of the country.)
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I use to pronounce alot of words the "Jersey" way but forced my self to learn proper english after spending so much time in the south. I was gal dern tared of being called a dag gum yankee carpet bagger every time I ordered a glass of wooder with ma grits!
17,833
SW Iowa
Wa-der.
orenge around here, there is no kick up for the "a"
I am close enough to Missouri a little of the southern twange is around where words sort of get mushed but without the full blown southern thing.
Junk Collector
Truck of Month
4,800
Rapid City SD
I have iron!
Very nice, you'll like that. FYI you can get aluminum liners at Walmart for those. I use them all the time, makes cleanup after things like cobbler MUCH easier.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
I have a 10" skillet that I've owned for probably 25 years, a 12" round griddle, and a dutch oven, all Lodge. The dutch oven is great for making tomato sauce.
Best way to clean old rusty ones I've seen is to spray them good with oven cleaner, put it in a garbage bag and leave it in your basement or garage overnight, spray it again the next day and put it back in the bag, do it again for a third day, then scrub it clean.
I wash mine with regular dish soap, it doesn't hurt them, then heat it back up on the stove, spray it with Pam and wipe with a paper towel and let it cool down before I out it away.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I just went to my parents house and dug through our old camping gear, there are 3 iron skillets there that match mine. No name anywhere? Do yours have names cast into them or you just know the brand by looking at it?
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
I have an engraver. I could put names on mine.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Junk Collector
Truck of Month
4,800
Rapid City SD
Easy way to identify cast iron... is it marked with Made in USA or Made in Taiwan/China/Korea etc? If none, and it doesn't have a brand name, and looks old, it was probably made before the 50's/60's. Sometime in there the cast iron companies all started putting Made in USA on their pieces.
Any numbers or other text? Do they have heat rings on the bottom? Those are a raised ring on the bottom of the skillet. Sometimes you can identify them by the number of notches in the heat ring or lack of. The vast majority of old, unmarked cast iron with heat rings I've come across has ended up being Lodge but there are many other brands too.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
48228
Anyone know what this is for.
Flat bottom, round bowl with a pour spout. No handles or spots to hold or anything on the top or side.
Found in a bush next to the garage.
think it was used planter at some point.
48229
48230
ericbphoto
16,598
Wellford, SC
6"
Looks like a pot for melting lead to join old cast iron sewer/drain pipes.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Yea definitely a crucible.
Junk Collector
Truck of Month
4,800
Rapid City SD
That's a cool little piece. Plumbing comes to mind, although from my understanding a lot of plumbers used a burner with a lead pot attached to it and a dipper. Weird that it has a pour spout and that it's so thick - bet that guy was pretty heavy and awkward to pick up when full!
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
It's heavy and awkward to pickup empty, with my hands, forget full of lead and using tongs.
