I don't understand the question, but that's par for the course with me.
The cross pin is stuck becase the binding bolt is broken. I've read threads about ways of getting the pin out, but I'm having trouble visualizing. I don't see how to drill/easy out the rest of the bolt without boogering up the outer threads. Obviously there are, because fioks have done it and that has been well covered elsewhere. Either way, I don't think I'm not going down that road, so I'll just leave that there unless the fix is stupid simple compared to the other options listed below.
Based on my current goals, skills, budget, parts availability, and lack of a place to have a truck laid up for more than 3 days, I'm probably swapping. Short of finding a Ranger rear end in good nick, I'm probably going to end with a 31 spline and disc brakes, so I have some immediate questions that I'd like to understand better, so I can get on with it.
Is there a guide somewhere about how to assess a differential in less than ideal conditions, like a junkyard or Craigslist seller's living room?
I'm confused about flip kits. Are axel kits like the one from rough stuff 100% bolt on, or am I dreaming? I was told they all need welding, but I have reason to believe otherwise. Can someone set me straight on this? Any favorite options or more info here would help me clear the fog. I know a bolt in is less strong, but it would simplify my problems in the short term. Any off-roading with be light for now, and this would be a temporary fix.
As I understand it, If I ran the Expo rear end as-is, it would drop the rear a bit. How far would it drop? It's got a 6" lift, and I could change the fron spacer in front to level it. That might not be a bad way to go. I can always restore the lift later. I think I just talked myself into that. Anybody care to make an educated guess as to the largest tire I should consider in this configuration? (six inch lift minus axle drop)
I need to get this truck on the road, stat AND I want to play a little while I have some time. That's the short term goal. I can alays go back and address later when I have time to organze my resources. Medium term, adding some all-terrain tires and a more permantent axle setup. Long term, a higher gear ratio, unless I find that 31's and a 3.83 is working for me.
Am I on the right track? Asking the right questions?
Thank you all again! I'm learning loads!
