Terrible wet weather traction: tires or truck?
cbxer55
767
Midwest City, Oklahoma
Thinking it may be tires. I was running Cooper Cobra GT's in the back for years. Then put on a set of ancient Cragar rims with BF Goodrich TA Radials. The Coopers would spin in the wet if you looked at them cross-eyed. The TA Radials don't. Rained here all week. Didn't spin them once.
Lefty
1,943
Saint Paul, MN
Ranger Edge
I have had very good luck with Cooper AT tires. Mine are also extra wide. My belief is that the factory stock is too small. I'm with @Blmpkin. The reg cab Ranger weighs less than many cars, 500 lbs less than a Mustang. Also, tires get dry and brittle and lose their traction after 5 years.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,892
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Which is a very valid point. I believe tire compound possibly being an issue was mentioned before. I have had that experience with one set of Cooper tires but not with others of the same brand but different models.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Yes thank you. Much better info than just beating the 55psi dead horse.
Stumblefoot
22
somewhere in Texas
Well you have a 4.0, others have an anemic 2.3 or 3.0 that could be partly why yours has "rain" issues. The tire pressure is probably your issue too. My 3.0 with programmer will spin the tires at will, and is kinda dicey in the rain. But manageable. A good limited slip rear axle would help alot.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I got the factory trac lock or whatever...I dont think it helps, I like to gas it out of turns lol. countersteering helps.
Lefty
1,943
Saint Paul, MN
Ranger Edge
I'm hoping to install limited slip this summer.
