Eddo Rogue
- May 18, 2020
- 2,505
- Burbank,CA
- Ranger 4x4
- Engine Type
- 4.0 V6
- Engine Size
- OHV
- 2WD / 4WD
- 4WD
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Wow I didn't think this would be such a hot topic, I appreciate so many responses so fast....seem to be a common and shared experience.
For all of you breaking my balls about the 50psi. You are correct, and it seemed high to me as well. but these are LT tires, so the sidewalls call for higher psi ratings. I have the same tires on my F150 (different size) and they call for 80 psi, which I run at 55psi loaded or not. They work fine, just occasional bumpsteer. The truck and tires ride much better loaded down.
Anyways back to the ranger, The tires dont look overinflated or anything...But I will drop them down to 30-35psi and try it out.
Also yea they are a little loud, but I don't care about things like noise or tread life. Being the last thing to touch ground holding up my 4000lbs of metal machinery, traction is my priority.
