Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Here is my post on my last dyno. Basically I have too much fuel for this turbo and if I wasn't worried about cooking this turbo I probably would have ended up with ~145whp. If I had a slightly larger turbo (vnt17) I'd probably be around 160-170whp.So what the current HP and torque on this thing so far I haven't gotten a chance to check the thread lately
Well I finally got a free day to run this back to the same Mustang dyno as I did before. Went pretty well. Didn't break anything.
I did have to stop the pulls short at 3800rpm due to EGTs. I'm not sure where it would have stopped but it appears to be climbing pretty nicely when I shut it down.
Stage 1 = vnt15, Malone tune (16psi), stock nozzles, 10mm pump
Stage 2 = vnt15, updated Malone tune (16psi), R520 nozzles, 10mm pump
A couple of videos..
Fuel pressure: https://youtu.be/r8TmdgXDc7c
Axle wrap: https://youtu.be/QQxBJZRj52o
Boost response: https://youtu.be/iI_pv7e_SiY
Last video is from my first run and it appears I stopped a little early (1610F). My third and best run I stopped at 1650F.
IIRC my buddy said the Mustang we used would trend towards conservative and not optimistic. I REALLY wanted to get a stock truck on the same dyno to serve as a baseline. Until then my dyno numbers are mainly for me to understand the gains made with each performance level.Your whp#'s match malones advertised chp numbers any thoughts on that or is this dyno known to be optimistic?
