Tach install In a 1984 Bronco II
SgtDan94
NorCal
Ford Bronco II
Title says it .. I want to install a tach in my 1984...
Is the Bronco II pre wired for a tach? What’s the easiest way to do this?
Thanks
franklin2
1,758
Virginia
Bronco II
I don't think that early model is pre-wired. You just need to hook up key-on power and ground, the wire for the dial light, which is going to be a lightblue/red, and then run a wire out to the engine compartment and hook it to the negative of the coil. That will pick up the pulses from the module and trigger the tach.
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just moved this thread to the correct forum...
