Wicked_Sludge
- Aug 6, 2007
- 43
- Age
- 38
- Westport, WA
- Ford
- Engine Size
- 3-point-GO
DO NOT TOUCH THE EXHAUST MANIFOLD BOLTS!!
leave the manifold bolted to the head to pull the head. instead, focus your attention further down the line at the 2 large down-pipe bolts. these bolts are much larger (15MM if memory serves) and stronger then the manifold bolts, and arent subject to quite the extreme heat that helps seize manifold bolts to the head. plus theres only 2 od them
pulling heads is easy. dont forget to drain the cooling system. unbolt the a/c-power steering bracket and leave it in the engine bay.
