Why? Wicked has done this a number of times.
The only thing I'd add is that there are a FEW potential things to remove beyond the engine mount, but nothing significant. From memory, it's the oil level sensor connection and the engine block ground. The HEGO sensor bracket will come off when the transmission is unbolted. To cut down on the mess, you should probably drain the oil, and remove the engine block coolant plugs normally underneath the back ends of the exhaust manifolds. Quite a bit of coolant doesn't come out the water pump or the radiator draincock.
I find it easier to pull a (nearly) fully assembled engine than a block, just because the exhaust manifolds are convenient for attaching the crane. RBVs do not have enough room to pull an engine and transmission together (especially if the transmission has a transfer case on the end). Though mating the two inside the vehicle is a big PITA, it's really what you have to do.
Remove the fan and clutch and perhaps the water pump in the vehicle. Get all the accessories out of the way (I like to wire the A/C compressor to the rad mount). Remove the radiator and put a piece of plywood behind the condenser to prevent another disaster.
Unless you are ready to spend a lot more money, all you're going to do on the block is replace core plugs and external gaskets. You can measure the crank and rod bearing clearances if you want with Plastigage, and measure cylinder taper (etc). But if you're replacing bearings or rings, you're in for a LOT more expense. You can have the block inspected at a machine shop if you want (it's not very expensive), and you should consider having the heads Magnafluxed.
A full rebuild costs nearly $2000, if the castings are good. I got mine down to about $1000 when I did the Chevy, because the block was in pretty good shape (no boring, just honing; reused the cam, crank, rods and pistons), and most of the cost was in rebuilding the F-d up head.
You probably DO need a valve job, perhaps including guides, but that's easily inspected for. A poor man's benchtop leak test is to turn the head upside down and pour ATF or some other light oil onto all the valves. Then, look into each port to see which ones leak. Make sure you don't rest the heads on the valve stems or you may get a false positive.
