Stripped a seat bolt Help!
Colin
182
ON Canada
Mazda
So while trying to remove my seats, so i could clean my filthy a$$ carpet i stripped the head on one of the torx bolts, holding the seat down, whats the easiest way to remove it?
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Can you hammer the next smallest socket down over what's left?
When I just did a console install one of my front outer seat bolts was rusted bad. I thought I was going to strip it too, but thankfully it did not.
Hope this helps!
Colin
182
ON Canada
Mazda
Thanks for the info, unfortunately they're torx bolts, would that still work?
graff104
Oklahoma
Cut it out!
Roadkill
Ontario, Canada
7.3l turbo
Use Vise Grips.
warrior24
Surprise, AZ
vise grips maybe grind or file the head square like.
snoman6115
Weston, WI
v6 4.0
ora take a hack saw or sumtin and cut a straight groove int eh head to use a flathead, but im all for vice grips and sum pb blaster
Colin
182
ON Canada
Mazda
Thanks for the advice guys.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I've used the hacksaw trick a few times...vice grips may or may not work...but apply plenty of WD-40 from the bottom side first and let it soak...the bolt stem should be visible from the under side...
Colin
182
ON Canada
Mazda
Well its going to the stealership tomorrow for something else anyways so i'll let them deal with it. All the help is appreciated though.
PlumCrazy
2014 Truck of The Year
178
Millersport, OH
Solid Axle Swap 4x4
Drill it out with a 1/4 inch drill bit (use lots of cutting oil), then drill it out to 1/2. When you put it back together use 1/2 inch bolts (atleast use grade 5 bolts, these are also part of the restraint system) with nuts on the bottom side (tack weld them to the cab if you dont have some body else to hold the wrench, or use an impact gun on the nuts) and use a little blue locktite. If it is a Super cab, make sure you dont hit the gas tank under the driverside seat belt bolt with the bit:icon_thumby:
I am pretty sure Ford put some sort of super locktite on all the bolts that the seat belts attach to. , thats why they always suck to get out in one peice.
-plumcrazy
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
99iowa4x4ranger
Walcott, IA
2.3/6.0
until you break the easy out..
MountainMike
84
Canada
245 CID
2"
31"
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
no, when you break the easy out in the bolt youre trying to extract then you are SCREWED because you cant just drill an easy-out out. i would suggest drilling the head of the bolt off with the appropriate size drill bit (so that the head is gone and just the threaded portion is in the floor pan), then apply a liberal amount of pb blaster to both the top and bottom. wait a minute, drink a beer or two, then crawl underneath with your vice grips and clamp the protruding end of the bolt and work it back and forth, until it gets easy to turn. then you can finish turning it out from the bottom which shouldnt take too long because youre going to be turning fresh threads through the nut instead of dragging the rusty ones through it.
