shift knob removal
fisherbud
PA
i have a 2003 ranger. Im not a fan of the standard shift knob. How do i remove it? and what other knobs would you guys recommend
ericbphoto
Overlander in development
16,665
Wellford, SC
3.0L
6"
If its like the older ones, a bit of heat and some persistent persuasion should do it. The shaft is splined, not threaded. Therein lies the frustration. Most aftermarket knobs seem to be threaded. So, search for an adapter or maybe epoxy something on. Or, replace the whole shifter with something else.
racsan
4,492
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
if you have some hot days left, park it outside with the windows up. Or take the whole lever off, bring it in the house & place in a boiling pot of water for about 5 min. Have some leather welding gloves on & it should pull right off.
8,372
+1 ^^^
Knob needs a bit of heat, it is glued on, glue will soften with heat and knob will expand a bit, once its warmed up, put correct size open end wrench under knob and tap it up with hammer
fisherbud
PA
any recommendations for new shift knobs that will fit?
8,372
Google: universal shift knob adapter
These slide over the splines and are held in place by a set key and you can then use the screw on type
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Tennis balls work well...
MikeG
752
central Texas
B4000
2"
235/75r15
Drill a hole in something. Epoxy or gorilla glue or practically anything else will keep it on. Even latex caulk.
Junk Collector
Truck of Month
4,839
Rapid City SD
I peel the boot down a little bit and use a blunt chisel to drive the shift knob off. Works most of the time unless it's been glued on previously. If you try twisting it, you're guaranteed to destroy it.
