Rear sliding window leak
5
Seattle
Ford ranger
Hey yall
1999 ford ranger xlt 4.0 4x4
Just wondering if someone could point me in the right direction. My back sliding window is leaking and am looking for where I could purchase new seals/gaskets. It’s not leaking from the fixed windows and is definitely from around the sliding window. But it leaks like crazy when it rains. I just have it duct taped for now and want to make sure to remove it soon so it doesn’t ruin the paint. Any help would be appreciated. Thanks
scotts90ranger
4,594
Dayton Oregon
2.3 Turbo
Are you talking about the seals around the sliding windows themselves or around the whole assembly? The whole window assembly is bolted in and has some butyl rope sealing it to the cab, the sliding part of the window just has some seals to try to keep most of the water out but relies heavily on the drains in the bottom of the window track to work to keep the rest out If you look on the outside of the window there will be some cutouts on the bottom side of the window frame to drain water, if there's moss in there it will leak. I don't think there are reseal kits for the sliding part of the windows but replacement windows are available...
5
Seattle
Ford ranger
It’s leaking at the bottom of the track for the sliding window, at least that’s where it’s pooling up and then coming inside the cab down the back wall and settling in the back of the cab under the carpet. I’ll check and see if the drain is clogged but I’m not locating where the drain actually is.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,662
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
There are a couple body dimples that come up to the window...
Drains are in the dimples if I remember correctly
scotts90ranger
4,594
Dayton Oregon
2.3 Turbo
Ok, I was way off, the newer windows are different than the older ones, I went out and consulted my slider I'll put in my '97 once I get there... there's still two drains but they're in odd places, I would chase them with weedeater line or something. The drivers side one is pretty straight but the passenger side one is far from... I was able to push a 8" zip tie through the drivers side one easy but couldn't get it through the passenger side...
5
Seattle
Ford ranger
Awesome. Thanks so much !!
