fourwheelford
- Jul 24, 2009
- 1
- washington state
- ford
- Engine Size
- 3.0 Flex
Ok this is the first year of 4wd for me and this thing seems really really noisy. I know 4wd is noisy but this seems wrong. 2000 3.0 ff with bout 110k on it newer tires all the same size. The majority of the noise comes when I let off the gas it will kind of whine like when you downshift a manual tranny to slow down the other noise is like a grinding vibration that also happens when I let off the gas if I push the gas just a bit it quiets right up it sounds like its coming from the passenger side. Sounds fine in 2wd and I had the fluid in both diffs and the TC changed this year and the front diff and TC were checked yesterday both full. Things seem worse when I have been driving it for awhile around town its fine.
I noticed a leak at the pinion and at the passanger side axel seal that only seems to leak after driving for an extended time I will replace the seals this weekend hopefully. It shifts into 4wd fine and seems to have no trouble pulling me around. Please someone help me I need the truck to get around in the snow any help would be great thanks in advance.
