provin1327
- Dec 14, 2020
- 0
- Colorado
- Ford Ranger XT
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
Hey guys, I'm running into a strange issue with my 2006 Ranger 4.0L auto 4x4. Last year I replaced the battery since it needed replacing. Easy swap, all went well. However, about a week later I was driving the truck out of the driveway and all of a sudden I lost all electrical power. Everything shut off and went dead for a second. Then all my dash lights and gauges turned back on, I turned the key and the truck fired up no problem. A few weeks later it happened again. Instant loss of all electrical power, truck dies for a second then everything kicks back on again and starts right up. My first guess was something with the battery since I had just replaced it but I got to thinking that if the truck is already running then a bad connection at the battery terminal or bad battery wouldn't cause it to loose all power and die. I decided to clean all of the relays and fuses and make sure they're all set in their slots correctly. That seemed to fix the problem until today when it happened again. This time the truck died for about 10 seconds and I had no power. I tried to crank it over and nothing, no gauges, no radio. Then all of a sudden everything turned back on and the truck fired up. What could be causing this? Based on how intermittent and short it is I feel like I should be looking for some sort of bad connection or loose wire but I'm not exactly sure where to look or what else it could be. Any ideas? Could it actually have been the battery? Seems highly unlikely since it's only happened a handful of times.
