Radius Arm Bushings
mas_fina
I recently bought some Energy Suspension raduis arm bushing and they look alot bigger that the OEM ones that are on my Bronco anyone have issues installing the Energy Suspension ones? The part number is 4.7110
TexCaliBII
4
Palmdale, California
That's the correct part number for a 2WD BII. If your's is 4WD you really need part number 61210. The part you have would probably work as the number I gave you also says it works for 2WD BII but the 4.7110 do not cross to 4WD BIIs. So they might work. As far a as I know the diameter of the radius arm "bolt" boss is the same. Thought the arms are different between 2WD and 4WD trucks as the 2WD are narrower than the 4WD where they attach to the axle but they should be the same in overall length and gain the bolt end should be the same. If they fit on the bolt end sungly and seat into the cradle holes IO'd think theu would be fine. Otherwise Energy Suspension will trake these back if you need the other bushings. Good luck!
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
No problems here, they are a lot bigger than factory though. I bought mine off of broncograveyard.com where it actually said they were bigger. They fit fine tho. You will have to re-use the plastic washer though as mine didnt come with them.
mas_fina
Bronco grave yard is where I bought mine, well I ordered Daystar's and they sent me Energy Suspension. The problem I had was the passenger side bushing the one on the outside closest to the nut was torn so I tried just replacing that one on the Bronco with the Energy one and there isn't enough threads for me to put the bolt back.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
They fit perfectly for me. :dunno:
And yea, They sent me energy susp. ones too where it said they were Daystar
kevinsranger
edison nj
FORD
if they are longer "not enough thread to get the nut on" then it may cause your front end to be pushed further forward and mess with the steering, suspension cycling ect.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
They were the same "length" as the old ones, just a LOT thicker was all in my case.
trail B2
8
North Eastern Ca.
I've put those in by throwing a come along from the front axle to the tranny cross member.Don't get carried away put a couple clicks in and the nut will start.
