Radio: muted when in Drive/Reverse
FillMarr
Ford ranger xlt
Hey all,
I’ve done some investigative work here. The radio works only in Park and Neutral, whether or not the truck is on or just the ignition is on. Problem is, the sound gets muted when in Drive, reverse, or in gear. The radio/screen/clock stays on, but sound is muted.
I noticed that each of the 3 radio fuses have power as they should (one always, another while ignition is on, another only when cranking).
Interestingly, there IS sound in Drive when I ground fuses 21 and 22 manually via my test bulb....so, prodding either fuse with the tip of the tester, while the tester itself is grounded via alligator clip.
So that means what? That my starter relay needs replacing? That my sensor relay on my tranny needs replacing? I hear people cut a red wire/black stripe at the back of the radio, but I’d rather do this right.
Thanks!
Phil
Ps- truck works perfectly fine otherwise. 175k miles, 2007 xlt, 4.0, automatic, stock radio (not tremor), vacuumed carpet. Some codes from my obd2 scanner seem irrelevant but are attached:
FillMarr
Ford ranger xlt
In the end, a new radio did the trick! Got a Sony touch screen, I love it.
FillMarr
Ford ranger xlt
Does that mean it wasn’t an issue with the radio in your opinion? Just curious at this point. Thanks.
8,370
No, probably not or it would mute all the time, not just in selected transmission shifter positions
The Sony won't have that Mute hookup
FillMarr
Ford ranger xlt
Fuse 28 seems fine. I have another symptom that could be related, I suppose as some type of anti-theft protection....
P1260 - "Theft detected, vehicle immobilized" possible cause: Antitheft system has failed. Possible fixes:
- replace instrument cluster,
- preform parameter reset procedure w/U2510
- replace instrument cluster module
U2510 - "Invalid or missing data for vehicle security". possible fixes:
- perform parameter reset procedure w/p1260
- repair Engine control module case ground w/U0100
- replace ignition keys w/U0100
- replace powertrain control module (PCM)
- perform PCM programming with P1260, U1900
- repaired PCM wiring w/U0100
B1602
B1352 - ignition key in circuit fault
- performed battery disconnect/reconnect w/ U1041, U1242
- repaired read door jam wiring
8,370
If you had battery connected while you were installing the new radio you may have triggered the anti-theft system
PATS, passive anti-theft system, is in the instrument cluster, and usually just vehicle/engine related, not sure if the Stock Radio has a connection that needs to be present or if replacing with non-stock radio causes the "theft" mode in 2007 Ranger
I wouldn't think so, as thats usually more of an "alarm" system not an anti-theft system
So not sure why you would be getting those codes
