Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Thanks. I was just wondering what it does. I've had some episodes of hard shifting. On Ebay there were a number of them sold so I was wondering if they go bad. Thanks.What purpose does the rubber bulb in there accomplish? Do they go bad? Thanks.
If you have the setup for it sure. The fluid does turn dark over time just like the fluid in the brake system. So using fresh fluid would be better.I've never seen low fluid level in there. Can't you bleed it like you do brakes? Run a hose from the bleed valve back up to the reservoir, slowly pump it and make sure the reservoir doesn't run dry? Thanks.
