Pros/Cons of 3.0 Vulcan V6
Ranger_XL
45
Wind Gap, PA
Ranger XL
Power/Durability/Reliability/Costs of Maintenance
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
well they are a reliable, long lasting motor, the 2 biggest issues I know of are the cam syncronizer (where the distributor was) . If its chirping, its on its way out. And the fact that they seem underpowered. This engine needs to be wound up, it makes its power pretty high in the rpm band and most of the time the differential gearing wont let it be running where it needs to be at. Id recommend 4.10’s minuimum, and thats with stock size tires.With the right gearing its not too bad. Id guess the maintenance/ upkeep costs are about the same as any other ranger engine. change the oil, plugs/ wires when needed and keep rolling down the road. the 2.3 is better on fuel and a 4.0 makes more power but a 3.0 isnt a bad engine.
Welcome to T.R.S.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Yup. What he ^^^^ said.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Pro - you'll never get a speeding ticket.
ericbphoto
16,598
Wellford, SC
6"
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
It's a good engine for a light weight passenger car or a 2wd pickup with 4.10 gears that's going to be used as a car by someone who lives in flat country. I don't know where Wind Gap is but I consider most of Pa to be flat, at least relative to NH & Vt.
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
My first Ranger was a 3.0 with a manual and 3.73 gears. It did pretty good like that, seemed to have adequate power and when I needed it to scoot, I ran the RPMs up. It was also a 2wd. Been thinking of resurrecting it as a run-around toy or something, it got wrapped around a tree like 10-12 years ago.
Ranger_XL
45
Wind Gap, PA
Ranger XL
Walt, Wind Gap, Pennsylvania is a valley located at the foothills of the Appalachian Mountains, known as the Lehigh Valley. A 3.0 Vulcan V6 would manage fine in Wind Gap's elevation, albeit RWD could be problematic without winter tires and weight in the bed. I have been contemplating putting money into my existing trucks (2003 F-250 SD SC XL with a 6.8 V10 mated to a ZF6 and 4x4 and 1996 Ranger RC XL with a 2.3 I4 mated to an M5OD and 4x4), enjoying them 9-1/2 months per year, and driving a plastic-clad vehicle (Aveo, Spark, Sonic, etc. with a manual) in the winter when the roads are laden with rock salt. I frankly do not want to expel time, effort, and money only to watch the tire wells and undercarriage areas rust again. Lil Blue, do you still have your 3.0 Ranger?
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Proper Gearing for a 3.0 is a must. I have 3.45's in my 3.0 ranger and while highway I get great gas mileage running between 2500 and 2700 rpm @ 65mph this also is under the power range of this motor. I live in a valley surrounded by mountains and constantly am shifting between gears to be able to pull them. A real pain so 4.10's are a good starting point in areas like ours.
Reliability of the 3.0s is high as long as you do your maintenance as you should. Cost of repairs is about average and cheaper in some areas but doesnt break the bank like Audi, VW, BMW ect. does in most cases.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Pro: it's 0.1 liter larger than a 2.9
Con: it's 1.0 liter smaller than a 4.0
8thTon
--- Banned ---
806
Pennsylvania
For a lighter Ranger with 4.10's it would do fine in Wind Gap. Also depends on what year, as the 2004 like mine is 154hp. If you've got an extended cab and 4WD and the weight is getting up there it will of course get slower - my 2WD goes quite well. When I had 300lbs in the back for winter traction it was noticeable, but hardly a problem.
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
I do still have it. Front clip is off of it and I have been too busy with other things to get back to it. Three-ish years ago I had to have hip surgery so I needed an automatic. Now I can drive a manual again, but...
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
You don't live far from me. There's a few of us on here in Pittsburgh.
3.0 is... Well. It's a taurus engine. What you see is what you get.
Agree with others. Go to UPAP in Pittsburgh, get a 8.8 limited slip with 4.10s for $75-125, carry a small tool kit and a few sensors under the the seat, and circumnavigate the globe a few times.
Pro: it's 0.1l away from greatness
Con: it's 0.1l away from greatness
FIFY
ericbphoto
16,598
Wellford, SC
6"
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
