Project Double R...
Stang5lgt
Four X Ford
Parker, CO
Got my brakes plumbed on the front and rear.
Fronts I used Chevy truck lines they cost about 15 bucks each. You can see all the part #s on the bag.
You will need a 16-20" line for the drivers side and about the same pass since you have more the lines to back side of the coil bucket. Drivers side you will need 3/16" T and Pass side you just need coupling.
And BAM! Less then 50 bucks later we are in business. These Chevy lines work great cause they are longer then most stainless and will stretch some if needed. Plus you can't beat the price.
Rear I just used the stock Explorer lines so nothing fancy to see there. :D
Stang5lgt
Four X Ford
Parker, CO
Rolled it outside brakes work good.
Just need some driveshafts, and get the gas tank hooked up and I can take for a spin.
Stang5lgt
Four X Ford
Parker, CO
Got some more goodies for Rock Ranger and I worked on the gas tank mounting it...
New winch...
LED tail lights...
Skid on worked out pretty good.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
i like those brake lines.....i spent damn near $40 on mine.
Stang5lgt
Four X Ford
Parker, CO
Picked up the tube for the flatbed, sliders, and should have enough for the front bumper. The exo cage steel should be here Tues had to order it.
86MUDRCJ
8
Sheridan, CA
It's lookin pretty good man! Keep it up.
Stang5lgt
Four X Ford
Parker, CO
Thanks boss! Last night I got all the measurements figured to keep the flatbed level with the truck. Since I cut off the rear bed supports I had pull a string line off the bottom of the cab and measure to a straight edge across the end of the frame.
Stang5lgt
Four X Ford
Parker, CO
Flatbed pics! It rained most of the day so it slowed me down a lot.
Stang5lgt
Four X Ford
Parker, CO
Now I need to build the sliders. Going to tie the flatbed roll bar into the sliders. The cab exo will land on the sliders too. Then I need to get the front bumper built so I can tie the front exo into the cab part. I can't wait to get it done. Going to be sweet!
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
lookin good sirs!
i like those lights, where'd you find them?
Stang5lgt
Four X Ford
Parker, CO
Stang5lgt
Four X Ford
Parker, CO
Got some bumper work done on the front!
Love this pic...
Stang5lgt
Four X Ford
Parker, CO
More pics and a couple with 35s on there rear. I need to get the new meats mounted up!
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
geez man....i'm trying to keep up but you're working too fast....lol
Stang5lgt
Four X Ford
Parker, CO
Sorry boss when I get this close I kick it into overdrive the closer I get the faster I go. At this rate I will be wheeling Double R by next weekend. LOL:D
