planing engine swap new gears needed. advice wanted
jrpdash9
eau claire pa
planing a engine swap with a engine that puts out 300 lb of torque give or take and im planing on putting bigger tires on it im thinking 35's. i was wondering if my factory 4.10's would still be a good choice or get a higher set or lower set any one know
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
What engine exactly are you putting in? (and will you be using an overdrive transmission with it?)
jrpdash9
eau claire pa
its a 5 cylinder benz turbo diesel its like 160 hp 300 give or take foot pounds of torque. and i dont think it is a over drive. ive been looking at the gearing chart and it says that 35's would be rather large for 4.10's but ill be doubling the torque so im kinda iffy on what im gonna do
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Hmmm.... Not familiar with that engine.
Do you know what axle ratio and size tires the vehicle it came from uses?
Being a diesel, I suspect your 4.10s may be fine, but I couldn't tell you for sure without more info about it.
jrpdash9
eau claire pa
the rear end that is in the car it is in is 3.07's. ya im in new territory with this diesel. so u think it would be fine with a diesel or should i go to a 33 inch tire to be safe
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Ok, we got 3.07s.
What size tires were on it?
jrpdash9
eau claire pa
only like 205's normal car tire
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
205/75R15?
(looking for an exact O.D here)
If its that exact size, then 4.10s would be just about a perfect match with 35" tires. :icon_thumby:
trail B2
8
North Eastern Ca.
My 4.0 and 4.10s works very well with 33's so thats a clue that the diesel would pull the 35's pretty well.
jrpdash9
eau claire pa
nice thank you i was debating between 33's and 35's and both would work. thank you guys =)
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
it's not only how much torque, but at what rpm your engine makes that torque to determine proper gearing
AD
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
JRPDASH... Sounds like a great swap! What year and motor is it? Im sure this swap will get alot of attention and questions. Post up plenty of pics and keep us posted! :icon_thumby:
