cp2295
- Jul 25, 2013
- 7
- Washougal, wa
- Ford
- Engine Size
- 4.0L swap, 8.8 explorer axle, IFS front end
- My credo
- If you ain't first you're last
Hi everyone I have a 99 ranger, with a 4.0 and ecu swapped in from a 98. I lost my keys up in the woods (ranger wasn't with me) and of course lost my only transponder key. I have a steel key still and have been able to get the rig started by turning the key to the on position, and then jumping the starter relay. Since it's a 98 computer it still sends power to the fuel pump, however it won't let the starter crank. Just wondering if there's a way I could feed power to the ignition switch so my starter will crank when I put the ignition to the start position. I'm skeptical about spending $120 on 2 keys so the locksmith can attempt to program the keys, but I don't think it will work since the ecu is totally different than stock.
If I have to I'm just going to wire a push button to the relay and use that, but I would like to try and avoid that.. Kinda hokey if you ask me but it may be my only option.
