Parking buzzer
DJFRY
Denver, CO
Ford Bronco II
Hi folks, I'm new to the forum but didn't readily spot an answer to this question on the site, so I'm hoping you might have suggestions for me: there have been a few times when I'll park, take the key out, and start to exit the vehicle before I realize I've left the truck in either DRIVE or REVERSE rather than putting it in PARK. I've only ever had it roll an inch or two before I caught it, but obviously this could cause a dangerous situation, either for me or for one of the other folks in my family who occasionally drive the B2. I'll work on changing my neglectful habits :) , but for the sake of added safety: does anyone know of a buzzer or small chime on the market that I could buy and install that would make a sound when the ignition is off, but the truck is not in PARK?
I just bought a similar buzzer from Jeff's Bronco Graveyard that sounds when I leave the lights on. That's what made me think something *might* exist to help with this parking situation. Ideas welcome. Thanks folks!
Roert42
4,985
Kintersville, PA
Ranger XLT
4.0 SOHC
I'm not familiar with your vehicle. However, a lot of the automatic transmission vehicles I've driven will not let you remove the key unless the transmission is in park. Potentially there is an issue with the lock cylinder?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There is a small pedal on the far left side by your feet.
Press it down when you park...
8,371
Do you have a Column shifter or floor shifter?
In any case the A4LD transmission will have a Park Neutral switch, called NSS
2 wires on this switch must be "connected" to pass starter motor activation on to starter relay/solenoid, which only happens in Park or Neutral
You could use two relays with those 2 wires that activated a buzzer if key/power was off and wires were not connected
But no, nothing "off-the-shelf" would be available
franklin2
1,765
Virginia
Like someone else mentioned, there is something wrong with your steering column. I don't know how they interlocked a floor shifter, but on a column shifter there is a mechanical device that will not let the key turn completely off and be able to pull it out without the shifter lever in park. If you have a manual transmission, there is a white button on the bottom of the column that you must push to turn the key back and take it out. Maybe they used the white button on the early automatic floor shifters?
There is nothing wrong in the column. The 1st gen automatics used the same key lock button that the manuals did (At least the few I have owned/worked on), It was entirely possible to remove the key without putting it in park on the one I actually owned. Back when these were designed they weren't built to be your nanny like today's vehicles, you were expected to pay attention to what you were doing, and to use the parking brake like @Dirtman suggested.
franklin2
1,765
Virginia
So it has the white button like the manuals do?
Cees Klumper
134
De Luz, CA (near Camp Pendleton)
Bronco II XLT
Mine has a warning buzzer for the lights (key out, lights left on - when opening the door, the buzzer sounds. It also sounds when you leave the key in the ignition, and open the door). However, they stop sounding over time due to age. There's posts on here on how to get it going again, which worked for me.
Just maybe it also chimes when you don't have it in park and open the door, I don't know.
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
/\ /\ /\ What he said. It's actually in the owners manual, too. And pay attention, I've driven a lot of vehicles too old to have buzzers and warning chimes. My 93 Ranger has a shifter from a 74 Mustang II with no lockout, no parking brake or door ajar warning lights or buzzers.
