P0316, P0306, P2272
Montanomo Bay
Victorville, CA
I just bought em a couple weeks ago and have driven around with em for at least 3hrs
Montanomo Bay
Victorville, CA
@RonD @adsm08
Dry compression test results:
Cyl - PSI
1 - 139
2 - 140
3 - 124
4 - 125
5 - 122
6 - 108
Based on the 15% rule, I believe 119psi is the lowest a cylinder can be at. Should I wet test the other low readings? In other words, wet test cyl 3 thru 6?
8,372
You average is 127, which is low in general but could just be the gauge or crank speed
And I prefer 10%
Yes, you can WET test #6 but unless it comes up to 130 or higher it has a valve issue
Montanomo Bay
Victorville, CA
And I prefer 10%
Wet test on # 6 came back with 115. I immediately tested again and got 110.
Montanomo Bay
Victorville, CA
@RonD @adsm08
I'm going to replace the head on that side with a brand new one. Any suggestions on the brand I should use? Any brands I should avoid?
Thanks!
8,372
Its a 2006 Ranger 3.0l so I would plan on replacing BOTH heads, they had a defect in the exhaust valve seats from 2004-2006
No, I don't have a specific brand name for these heads, someone may come back with that info
Montanomo Bay
Victorville, CA
Update: My last mechanic said he had both heads sent to be machined in 2018. He doesn't think it's the valves, he said it's probably the rings or hydraulic lifters. Does this sound accurate?
Well, is the heads are only 2 years out from an overhaul then they aren't the top of my suspect list. Do a compression test, dry then wet, and see what happens.
Montanomo Bay
Victorville, CA
Thanks. If you look a few responses back you will see the results of my dry test. The wet test showed a slight improvement in cylinder 6, but nothing significant
