eightynine4x4
- Oct 15, 2020
- Reaction score
- 178
- Location
- New York
- Make / Model
- Ford Ranger
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
So I’ve got to fix this small leak at one of the brake line fittings in rear. I had not touched it and only discovered it while doing the rear stuff.
It leaks along the line juncture itself, not around the threads.
I’ve tried tightening it with no success, but did successfully get it slightly undone. So it’s leaking a little faster although still very slowly.
Does this leaking along actual line mean something different than if it was leaking just along the threads? Maybe that the line tip/end will have an issue still even if I replace the fitting?
Also what size is the fitting? I’d like to have new one on hand before opening this up.
