One micron bypass filters clean oil = no engine wear
WildSide
Real clean oil means extended oil changes up to 20,000 miles and beyond, tests prove that the standard crap filters we all use remains to be the main contributor to engine wear as well as unnecessary oil changes. High quality bypass filters eliminate the above issues.
Thoughts? And let’s hear some real comments from real engine guys – post your peanut gallery and BS comments elsewhere!
rickcdewitt
5
nor-cal
4-0 swap
oil still oxidizes as it sits in your engine even if you have a fancy filter.you'd need an oil with a high resistance to oxidation if you wanted to leave it in there for longer than 6 months.although combined with an electric pre-oiler it might be a slick setup.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
As I recall, there was a test done on a mack truck engine, they filled it with Amsoil and hooked a bypass up to it and drove it for over 400,000 miles without changing it, then a independent engine builder tore it down and claimed the wear looked like a normal engine using dino oil with normal changes and it was super clean inside.
Simple_serf
Sherman, NY
We do somethng similar to this at work with our large refrigeration compressors. Very high filtration, moisture separators, etc. When you have a room full of $40K compressors, I guess it makes sense.
As was stated above, oxidation is going to be a problem regardless. Also, moisture contamination will still be a problem. around here, with our high humidity and large temp variations, you gets lots of condensation, which means that you still get corrosion in the motor, and the associated problems with rust and such. In addition to this, the additive package does wear out, and high filtration cannot fix that.
As I have said in the RP thread, My truck has run 193K miles on dino oil, and I have many other industrial engines that have very high hours (sometimes over 10K hrs) on dino oil with no problems. Most of these use a plain automotive type filter (I forget the Napa # I run on the Onans), and have NO problems after thousands of hours.
I have thought about using syntheics and high filtration before, but in the end it's not worth it (YOU try getting a 50 Yr old industrial engine That's still in use to stop leaking... I'll let you start with a 6-71 Driptroit :taunt:)
Still, I would be interested to see the results of adding a bypass filter and running synthetic on long term wear on a modern engine.
Jorley
Crawfordville,Fla.
2.8 duraspark
On older, high mileage engines wouldn't you also get some blowback from worn rings and such? That could contaminate/thin the oil, couldn't it?
Bob Ayers
16
Durham, NC
Scamsoil also tries to deceive you into believing all of their oil products are API certified too, when only 2 are API certified! They also lie when they say their ATF meets the specs on Dexron VI, Mercon V, and Mercon SP, when the viscosity spec is different on all 3 of these ATFs!!
thegoat4
6
Fleetguard makes oil filters for large diesels that have two sections. The top looks just like a standard oil filter with pleated paper. But the bottom section is a thick stack of papers with holes punched in them. It acts as a small-micron bypass filter. Those filters do certainly improve the oil cleanliness, but customers who never change their oil are still big business.
almostclueless
Wildside, all your opinions are INSANELY accurate, and I personally think haynes, chilton's, EVEN THE ORIGINAL VEHICLE MANUFACTURERS should have you write their service manuals.....you should even personally certify all ASE mechanics!!!!
LearjetMinako
12
Moore, OK
2.3L 140ci
I some how get the feeling that I will need to post my oil results after 5k miles on it.
Oil is Royal Purple 5w-30 and a Motorcraft FL-1 oil filter. Full oil change done @ 5k miles. I'll be getting a third test done when the Ranger hits 110k miles and I change the oil
dude772
Caledonia, Ontario
5.0L
so what is a micron bypass filter??
MrE_Powers
12
st. chuck county, mo.
3.0,4.6,2.8
i doubt it will reduce engine wear. most engine wear come from the oil sitting at the bottom of the engine when it starts up and not at the top. it take a few revolutions to get it to the top which is only seconds.
WildSide
Ok I should clarify a few things, I am talking about remote bypass filters and not the bypass type filter in general that engines typically use. Reading up on how poorly the typical oil filter performs even if does meet engine manufacturer specs, you can see how unprotected engines really are.
Regarding oil starvation during startup, wear can further be reduced by using oil formulated to protect during dry starts and if an accumulator is used… then how much wear would an engine be exposed to overall?
scotts90ranger
4,373
Dayton Oregon
2.3 Turbo
I've heard from our resident GM engineer at work that anything under 10 micron removes the adatives in the oil that help water contamination and aging, so you'd be shortening the life of the oil...
gotmudd
PORT ANGELES, WA
FORD
390C.I
the main contributor in engine wear as i see it isn't the type of filter you use
it's the "dry" start you get when your oil has settled to the bottom of your pan along with the oxidation[ several of you have mentioned in this threads past posts] you get when ALL oil sits for extended periods. if you want a "HIGH MICRON FILTER " use it where it do the most benefit, in your air and crankcase breather, that is where most of the harmfull crap gets in to the motor from in the first place. if you want to decrease engine wear find a way for us to have 100% "wet starts when we start our engines:pray:
WildSide
I would like to see the molecular size of those additives! Besides the filter would clog up and stop working within a very short while which I have found no reports of so far.there are bypass filters that have an additive package built in to them but oil companies would recommend against such of course.
