kukaepe
- Sep 15, 2009
- 1
- MAZDA
- Engine Size
- 3.0L V6
I have experienced the oil pressure gauge flickering or bouncing from high to low at idle on freeway off ramps. Seems to happen when traveling for 15-20 minutes at around 2500 rpm, exiting the freeway and at the stop at the end of the off ramp the gauge bounces all over the place and makes noise. I replaced the oil pressure switch as recommended on these forums and it only fixed it for a week or so and then started again. I purchased a "superseded" genuine Ford switch #6U5Z-9278-D (SW-6357), the parts guy said that it was a "5 psi" switch. This cured the problem, I hope this helps someone else with this same annoying issue.
