Nomenclature of the rolly thingies
snoranger
Professional money waster
ASE Certified Tech
13,663
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Toe-May-Toe
Unless your English then Toe-Mah-Toe.
You know the people who can't say aluminum correctly.
They also can’t spell aluminum correctly... they spell it aluminium.
Lefty
1,853
Saint Paul, MN
Ranger Edge
I'm sure glad I bought my rolly thingies already. I would still be on the phone with Rachel.
17,879
SW Iowa
For tractors which have wheels that come apart it is:
Hub: thing on axle that holds the wheel. May be part of the wheel.
Center: the middle part. Can either be "pressed" (stamped steel) or cast (cast iron for extra weight)
"Rim" held on the center by wedge locks, several styles of mounting like bevel or spin out etc.
Rim is what holds the tire.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Depends on where you live in the country. To-ma-to or to-mah-to / po-ta-to or po-tah-to, let's just call the whole thing off.
Do you call it a wheel and tire combo or a rim and tire combo...
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
The guys with saggy pants and fart mufflers on Civics call them rims. That's an additional reason to call them what they are, wheels. Model T's had steel rims and wooden spokes, bicycles have steel rims and metal spokes. Cragar SS wheels have steel rims with aluminum centers that are prone to breaking on an old tire machine like a Coates 10-10.
Junk Collector
Truck of Month
4,807
Rapid City SD
Toe-May-Toe
Great, now let's talk about toe-may-toe pasty stuff that has sugar and seasonings in it. You know, the stuff that goes on fries. What's that called?
:rolleyes::oops::sneaky:🤪🤓 I love semantics!
ericbphoto
Overlander in development
16,617
Wellford, SC
6"
French fry sauce.
sgtsandman
Aircraft Fuel Tank Diver
12,663
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Heinz ketchup. It’s the only tomato paste stuff you put on french fries. Everything else is a failed copy.
snoranger
ASE Certified Tech
13,663
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I’ll just leave this here:
73143
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
So?
The tire goes on the rim. The rim is on the barrel. The barrel goes onto the wheel. The wheel is on a hub. The hub goes on the studs. The studs are on bearings. The bearings are on a chase. And the chase is on the spindle.
That sure is a mouthful. I think I'll just keep saying "wheel" or "rim" as interchangeable words.
ericbphoto
16,617
Wellford, SC
6"
So?
Oh, that is sooo messed up.
Jazzer
457
Indianapolis
I thought that was a perfectly cromulent explanation……
-Jazzer
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
don4331
1,346
Calgary, AB
5.3
Bicycles have aluminium or carbon fiber rims, steel/titanium or carbon fiber spokes*, brass or aluminium nipples, aluminum or carbon fiber hubs and steel or ceramic bearings and when they are assembled the composite is known by largest part aka rim. Then you add tire (and tube in some cases) to make a wheel.
*I have heard of aluminium spokes, but I am too ...robust... to want to try such creatures..
Lefty
1,853
Saint Paul, MN
Ranger Edge
I would imagine that every single part which comes from Ford has its own distinctly name. Who knows? That might even be somebody's full time job.
